Z930R - Zero Turn Purchase - Comments and Rules of Thumb?
   / Z930R - Zero Turn Purchase - Comments and Rules of Thumb? #11
I just mulch all of mine. Pretty amazing how they disappear.
Does it take a lot of passes? We have a lot of trees surrounding and in our yard, and the massive silver maple trees in particular, absolutely blanket the yard in leaves. My mulching blades probably manage to pulverize 1/4 to 1/2 the total leaf mass, leaving it in the lawn, but I still end up shooting the remainder into the woods and gardens that surround the property.
Grinding it all into the lawn would shift soil pH and screw with my carefully-managed fertilization plan, but all that can be worked out with a little testing and trial. My mower could easily last another 10+ years, but seeing as I will probably keep this property longer than that, upgrading now might not be the worst thing in the world.
I did price out the mulching deck for my mower, but the stamped pan alone was like $3800. They said to figure over $7k to build that deck from the parts counter, since the mower is out of production now. :rolleyes:
All of my mulching kits have been permanent. I guess you could take them off but you wouldn't want to. I love mulching everything.
I'll keep that in mind after putting it on. If it does the job, then why change. Clippings make good fertilizer. Thanks!
   / Z930R - Zero Turn Purchase - Comments and Rules of Thumb? #13
I'm just surprised by how fast these things go. wow.
LOL... I remember thinking that, at first. Like every fast car you've ever owned, it starts to feel slower with time. Particularly in October/November, when it's effing cold out (with added 10 mph windchill!) and you're racing to beat sunset on each mowing... then it'll feel too slow!
My JD dealer advised against it. He indicated that once you put it on it can be a costly repair to it if something goes wrong. if you have a way of getting under and putting the kit on, then it is a cheaper alternative.
Can't be any slower than a lawn tractor at full RPM (loud as hell) putt-putting across a 5-hour grass cutting chore....
   / Z930R - Zero Turn Purchase - Comments and Rules of Thumb? #16
They still had the kits NOS for a few hundred on ebay two years ago, maybe I should've grabbed one then! I'll check again tonight.
Argh. I had my delivery this week and unfortunately the raising/lowering of the deck would not work. Tech came out, looked at it, and needs to take it in. Puzzling…. You‘d think they would have checked that before they came out with it.
I’ve never had issues with this dealer - so it is a first. But frustrating as I waned to use it to cut my grass today and had to revert to the X320..
oh well!
Basic theory:
1. Do two perimeter passes, clockwise to shoot all clippings onto your own lawn rather than street/neighbors.
2. Do two passes around each building, counterclockwise to shoot all clippings away from building/patios.
3. Pick a property line as your alignment, and start making stripes.
4. Learn to do K-turns (or "Y-turns") at end of each strip. You do not pivot on the spot, that will tear a divot out of the lawn at the end of each stripe.
5. Use a different property line or diagonal for each mowing, preferably having 4 different directions (N-S, E-W, NE-SW, NW-SE) to even out wear and rutting.
There are many finer points, but this will get you started. Oh, and learn to use mower deck lift pedal at every bump, esp. if deck is 60" or over. After some practice, you may choose to reduce your perimeter passes to one, after you've learned more efficient K-turns. It's a matter of care versus speed, and I tend to do just one perimeter pass but two passes around buildings.
I’ve just started to use my Z-Turn and it will take some getting used to when it comes to speed. My yard is a bit bumpy in spots so rather than going too fast, I’m taking it slow. I also have alot of obstacles (flower beds, etc.), so I’m thinking that until I’m really used to the turning, speed, and management of the blade width/spots, I’ll just need to take it slow. Agree?
Thanks for your insight, @WinterDeere !
oh well!
Problem resolved. Apparently a fuse was corroded (from sitting on the lot - the cover was bad) and now things work great!
Question on Servicing…. Do the folks here do their own service/maintenance?
Toro (A56857)
Toro (A56857)
20704 (A55853)
20704 (A55853)
2020 CATERPILLAR 299D3 SKID STEER (A60429)
2020 CATERPILLAR...
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52707)
(INOP) 2019 KUBOTA...
2020 HINO 268 26FT NON CDL BOX TRUCK (A59575)
2020 HINO 268 26FT...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
