What did you buy this week?
/ What did you buy this week? #581
I’ve kicked around buying some kind of water softener setup for car washes but I’m trying it without. I bought a TDS meter and tried it in my house which has a softener. The water showed a higher reading after the softener than the raw water coming in the house. I actually almost called the softener company but then I read online where that’s normal. The softener removes the “undesirable “ hardness but doesn’t lower the TDS. The water is better as far as spotting goes with the rural water we have now than the well water we used to have.
Our well water is high in calcium and lime. At least the sprinklers don't stain the house orange as with iron.
/ What did you buy this week? #582
I tried out the foam cannon today. A couple of reason I bought this. The first is cost, car washes here keep jacking up prices. The second is the quality of the wash. Just an estimate but I’m probably saving about $5 every time I wash at home. I’m hoping water spots don’t become an issue. My wife’s car is pretty forgiving being silver, we will see how it does with black paint.
What I ended up doing (lazy) was buying some $1 gallon jugs of distilled water and I just slop one of those around after am done washing. Then I get out the leaf blower 🤣🤣🤣 for a quick blow job (no pun intended) and voila, done..
/ What did you buy this week? #583
Car washing here is regular (town-supplied) tap water. Wet vehicle, spray on 50/50 mix of water and car wash soap, go over the whole thing with a soft brush, rinse and chamois. Takes only minutes. No spots.
Sometimes straight purple cleaner sprayed on tires & wheels and a stiffer brush.
/ What did you buy this week? #584
I have a soap cannon, works great. Mine goes on the pressure washer.
I also built a filter for a spot free rinse. A 4" x 20" water softener cartridge, then a 4" x 20" deionizing cartridge.
I get water spots from my water like crazy, especially on windows is not cleaned right away. Can you explain how you hooked your cartridges up to a garden hose or pressure washer set up? Thanks
/ What did you buy this week? #585
I don't use it for the pressure washer. It's kind of a stand alone system. Water piped to it, then a designated hose for the D.I. water. Two cartridges piped together and hung on the wall.
/ What did you buy this week? #586
Ok, I figured it was probably just for a hose rinse off which makes sense. I guess my main question is... What cartridges did you use to connect to a garden hose? Or do you have it set up coming from well water to an outside bib then just connect your hose like normal? I'm trying to picture this in my head and can't get a good grasp on it...
/ What did you buy this week? #589
It's hung on the wall in my garage. Hooked up to a hose connection with a 1 gpm flow restrictor, then to a hose connection with a hose and nozzle
/ What did you buy this week? #591
Dodge Man have you tried the rinse that is used in washing
glasses so they don't get spotted?
I use cascade in my wash bucket when I wash the car
and I don't have any water marks
willy
/ What did you buy this week? #592
willy
I used the green stuff after the foam wash. It really helped the water bead. It’s meant to be a rinse.
/ What did you buy this week? #593
Bought a load of topsoil mixed with mushroom compost.
/ What did you buy this week? #597
I got tired of wiping them down with a shammy, so I bought a Toro F 700 leaf blower and if the rig has decent wax or Ceramic coating, it leaves the vehicle pretty spotless - but need earmuffs, it is Loud.
/ What did you buy this week? #599
Replacement headset. Lost the one my son bought me for Fathers Day last year. :(
I hate it when someone you love buys you something you really like and you lose it.
/ What did you buy this week? #600
That stuff can really make your plants grow.
We use a “little” of that up here in the rust belt.
2014 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A60352)
2014 Chevrolet...
2019 CATERPILLAR  XQ35 GENERATOR (A58214)
2019 CATERPILLAR...
John Deere 6120M (A57148)
John Deere 6120M...
1969 Lincoln Continental Mark III (A56857)
1969 Lincoln...
2012 INTERNATIONAL 4300 4X2 26FT NON CDL BOX TRUCK (A59908)
2012 INTERNATIONAL...
2020 FREIGHTLINER M2 4X2 26FT BOX TRUCK (A59908)
2020 FREIGHTLINER...
