Attached GARAGE (homeowner) thoughts
/ Attached GARAGE (homeowner) thoughts #41
Ours smallest possible 3 car garage came with workbenches and cabinets on three sides of the garage. Since the barn's no good for working on cars, motorcycles or bikes, the garage became a garage/shop and the parking went from three small spaces to one.
My ideal would be an attached garage for the driver cars and two wheelers with space for bicycle maintenance and minor car maintenance, a barn for tractor and implement storage and a shop for storing and working on tractors, implements and fun cars. Oh and covered truck parking somewhere too. I don't daily drive the truck so it doesn't need to be in the daily driver parking.
/ Attached GARAGE (homeowner) thoughts #42
For me, a minimum length would be 30' to fit large pickups fully inside and still have some room to walk in front and do engine work w/o having to back the truck out some.
Minimum door is 9' x 8' (9' wide, 8' high) to fit w/o having to fold large mirrors. As someone said earlier, a standard 10'x10' door is a good minimum that's readily available.
/ Attached GARAGE (homeowner) thoughts #43
Detached garages, etc. make a lot of sense. However, in our area the zoning is very restrictive on added structures. My 2000 square foot pole barn is actually non-conforming on my 4 acres but is grandfathered in. A friend of mine had to design a covered walkway to his pole barn to get it permitted. However, he never got around to finishing the walkway.
Too much gov. intrusion, I’d say. 2000sq ft on 4 acres…geez.
I have two attached, three detached, and even one off-site. Guess which vehicles get used almost 100% of the time? The ones in the attached garage, out of sheer convenience.
That said, if building my own house, I’d just have 6 garage bays all detached. A breezeway would be nice, but is also a connection to the main house over which fire can travel.
I have doors ranging from 7 feet to 10 feet wide, all 7’ high. The pickup truck fits thru the 8 ft wide doors, but with less than an inch spare to the mirrors on each side. It works when needed, but not a great option for daily use. 9ft or wider would be fine for most trucks, and my 10 ft wide door works well for trailers.
This is the reason for our garage. I too have a detached barn/shop/with which houses a lift for vehicle(s). However, getting older and going to the "Barn" to drive one of the vehicles is taxing as it is a great distance from the house! Our solution is to bring up a vehicle or two and keeping them close so they can get driven. It will be nice to drive the Model T and the next day drive a convertible. The reason for the attached garage was stipulated by my wife - who is tired of scraping 'frost' from the windows in winter! We are not the "hip generation" who has lithium batteries in their vehicles nor do we have a Battery bank to run the house when the power goes out. All this technology prevalent with smart houses, ring cameras, combined with surveillance. The wife has made it clear; "Nothin' but vehicles OK.... Honey"! I concurred
/ Attached GARAGE (homeowner) thoughts #45
I’m not sure what my doors are on my shop, I think 8’wide by 7’ high. It’s a tight fit with my F150 and I owned a 3/4 ton Dodge and a 3/4 ton Chevy that were very tight for height. Our house has a two car wide door so width isn’t a problem but height is still tight.
/ Attached GARAGE (homeowner) thoughts #46
I have many saws….the doors can always get bigger!🤣🤣
/ Attached GARAGE (homeowner) thoughts #47
I was going to have 10x10 doors on my pole barn, but my buddy talked me into 12x10 doors. I'm glad I listened to him.
/ Attached GARAGE (homeowner) thoughts #48
Having the classics close at hand so ready on a moments notice is a luxury...
I always have to go to a separate address if driving the Model T or Model A...
Having 6 cars in a 22 by 30 means only 2 are ever at the ready.
If I ever built I have lots of ideas how I would want things... it comes from years of walking around with a measuring tape.
My home is just shy of 2 acres but detached structure prohibited...
The walk out shop area is ample but having 3 garage doors less than 8' wide and 7' high wouldn't be my design.
9 wide would be super plus an extra 6' to one side for all the occasional tools and supplies...
/ Attached GARAGE (homeowner) thoughts #49
I wish but the welded steel I-beam columns and headers design to meet earthquake pretty much eliminate a simple mod plus it all supports the upper floor.
/ Attached GARAGE (homeowner) thoughts #50
How many have a sprinkler system in the garage? 20 years ago, in Atlanta, Georgia area, new construction included a sprinkler head over the vehicle. With EV's today, seems like a good idea to slow the fire.
/ Attached GARAGE (homeowner) thoughts #51
Water is NOT GOOD for a lithium battery fire!
/ Attached GARAGE (homeowner) thoughts #53
Actually, water cooling is the currently recommended fire fighting technique- everything is about keeping the fire as cool as possible. Getting the cells below 500C is critical. A new firefighting method from Sweden shows real promise. It is basically a pressure washer that can cut into the battery to inject water into the cell area to get the temperature down.
However, the whole lithium car fire concern is grossly overblown, and not supported by fact.
Lithium EVs combust at 5% of the frequency of ICE vehicles, a number the adjusts for the differences in numbers. I.e. an EV is a (much) lower fire risk by a lot compared to a typical ICE.
Extinguishing the EV Battery Fire Hype (nice data from Sweden)
All the best,
Peter
/ Attached GARAGE (homeowner) thoughts #54
I've always suspected this, but I think the issue for some is timing. ICE's seem more likely to combust while in use, due to things like rodents nesting on exhaust manifolds or fuel system leaks in the engine compartment. But EV's seem more likely to spontaneously combust while charging in your garage, with your kids are sleeping in the bedroom above. Lower frequency, I had always suspected, but higher impact.
/ Attached GARAGE (homeowner) thoughts #55
You raise an interesting point, but I'm not finding actual data for fires while charging vs other sources. That said,
"From 2012 – 2021, there has been approximately one Tesla vehicle fire for every 210 million miles traveled. By comparison, data from the National Fire Protection Association (NFPA) and U.S. Department of Transportation shows that in the United States there is a vehicle fire for every 19 million miles traveled.
In order to provide an apt comparison to NFPA data, Tesla’s data set includes instances of vehicle fires caused by structure fires, arson, and other things unrelated to the vehicle, which account for some of the Tesla vehicle fires over this time period."
Note that the fire rate above includes all fires regardless of cause for Tesla vehicles.
All the best,
Peter
/ Attached GARAGE (homeowner) thoughts #56
It would also be interesting to see how many fires are the result of crashes for ICEs and EVs. A lot of nuances in the data.
/ Attached GARAGE (homeowner) thoughts #57
I agree. That is the data that I tried (and am trying) to find. As far as I can tell, crashes are a common cause for fires in both types, but I'm not coming up with solid data for the frequency. One source pointed out that for EVs, the fires tended to have a delayed onset, unlike gasoline fires, but I would prefer to see data rather than anecdote.
Plus, there is the demographic factors as well. E.g. Are EV drivers different in their driving habits? Not 16? Older? But not too old? All probably relevant at some level, but those factors and the EV itself add up to ten times lower frequency of a fire.
All the best,
Peter
/ Attached GARAGE (homeowner) thoughts #58
There are so many studies out there on thermal runaway due to mechanical damage, that we know accidents must be either a leading cause of battery fires, or at least thought to be a leading probable cause. But we also know from 20 years of Li-Ion tech in laptops and phones, that if they're going to catch fire without mechanical damage, it is almost always while charging. EV batteries are a little more complex than those in your laptop or phone, LFP technology, but I was making the leap from one to the other based on the number of news stories showing EV fires while parked.
Maybe I just fell for their narrative, but if EV's are catching fires in garages, I'm not sure why anyone would make up a false narrative that charging was a key factor... in fact it would be even scarier if it were not. After all, if they only catch fire without mechanical damage while charging, I can control that by just programming charge time for when we're awake.
/ Attached GARAGE (homeowner) thoughts #59
I think that when things are new, stories get coverage. I used to read old newspapers (long story) and in the early 1900s there are a bunch of stories of cars and garages catching fire from gasoline. Fires in stables weren't uncommon, but not as newsworthy, and usually buried in the back somewhere.
I think that the same thing is going on with EVs; they are new, and that makes news about them newsworthy, not to say clickbait, but like a lot of things, in can be hard to keep the entirety of the picture in view.
I think the same is true in medicine, with great coverage of the latest drug, or procedure, or article, with a lot less about exercising, getting out in nature, and having, and maintaining, a good social circle- too boring.
All the best,
Peter
/ Attached GARAGE (homeowner) thoughts #60
All the best,
Peter
"one Tesla vehicle fire"
What about other brands of electric cars?
Do Bolts catch on fire?
/edit - quick look- yup they do.
Actually I'm more concerned about all my DeWalt 20V and Flexvolt batteries, and ensuring they are unplugged.
for instance
