Auger bit for stump removal? Really??
/ Auger bit for stump removal? Really?? #1
RadarTech
Elite Member
North Carolina
2007 Kubota L3400, YANMAR YT359C
Ok.. I saw this auger bit that someone supposedly used on a Facebook post for a stump grinding..
the more question I asked, the more I doubted…
To save yall the collective bung output, I wonder have yall seen a bit used for that?
Edit— add.. I was told he just added it to his 3 point hitch post hole digger….
/ Auger bit for stump removal? Really?? #6
I cant see how that would work. Theres no down pressure.
That’s what I said too.. still trying to figure Retta out
/ Auger bit for stump removal? Really?? #8
Maybe on a skid steer.
but i still doubt its very effective. Need multi teeth gringing action, not drill.
me, i push tree over , root ball and all
/ Auger bit for stump removal? Really?? #9
That "screw" in the center, does pull the bit into the wood... I'm not saying anyone took a stump out with one, but I'm betting it will self feed.
SR
/ Auger bit for stump removal? Really?? #10
I looked at stump planes for my ssqa auger, but I don't think my tractor has the hydraulic umph to handle it. The ones I've seen on YouTube required down pressure, and were all on skid steers, or very large ag tractors.
/ Auger bit for stump removal? Really?? #11
Sorry, no way that screw would pull that thing thru a hard root. Heck, even my self feed wood bits dont really pull it thru wood.
/ Auger bit for stump removal? Really?? #13
As others have said, maybe on a SSQA auger. There's no way I'd hook that up to my 3pth unit. What happens when it gets stuck and you can't reverse it?
/ Auger bit for stump removal? Really?? #15
Auger gets stuck then out comes the chainsaw, axes
sledge, wedges:unsure:
willy
/ Auger bit for stump removal? Really?? #16
The guy who did my tree work had an expensive stump auger for his CTL that he said he regretted buying because he said it was so slow.
/ Auger bit for stump removal? Really?? #17
They make special high TQ low speed hydraulic drive augers for these stump grinders.
/ Auger bit for stump removal? Really?? #18
They also make cone splitters. Perhaps one could knock the stump into small enough pieces that it would come out with other equipment.
2003 Ford F-350 Flatbed Sprayer Truck (A61573)
2003 Ford F-350...
40ft High Cube Shipping Container (A61572)
40ft High Cube...
(2) UNUSED 17.5L-24 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED...
2017 Bad Boy Outlaw XP 61in. Zero Turn Commercial Mower (A61572)
2017 Bad Boy...
SCAN TO RECEIVE TEXT UPDATES (A64280)
SCAN TO RECEIVE...
(1) 16"X26'7"LO-1 1/2" THICK CULVERTER PIPE (A64281)
(1) 16"X26'7"LO-1...
