Berry trellis
/ Berry trellis #21
I initially ordered 150 bare root raspberries, 5 varieties, 30 of each. I planted two 100’ rows. 4 varieties are primocane, 1 is Floricane. That was 10 years ago. They bear from mid-August until first frost in the fall. My experience: I cut back the primocane varieties every winter and every year they produce new bushes about 4’ in height and they stand pretty well without trelliss support. I get about a gallon of berries every 3 days during peak production. These are winners. The floricane varieties aren’t good for my area. The old canes don’t overwinter very well and production is low. I grew tired of selectively pruning the old canes and now I just cut them all down every other year and get some berries on off years. In my climate, floricane berries aren’t worth it. They probably do better in climates with warmer and wetter winters. I’ve thought about doing away with the 30’ of floricane plants, but the only way to do that is with herbicides or root ripping. So I just let them go and enjoy a few berries now and then. Speaking of which, 200’ of berries is too much for personal use, so after I put about 15 gallons in the freezer, and eat them fresh daily for a month, I just let all my friends and neighbors pick them. Management is easy: cut back and dispose of canes in the winter, fertilize in the spring and once in the summer, and till between rows a few times a season to contain the bushes to a three foot wide row.
/ Berry trellis #22
Primocanes starting spring regrowth.
/ Berry trellis #23
Mr. J, lots of valuable information packed into your post above.
Note you're in New Mexico, and also aware that NM has a wide range of seasonality based on region and elevation.
What are the winters like in your immediate area?
Just wondering for reference related to the two different varieties you mentioned.
Also, do you have a favorite raspberry cultivar?
/ Berry trellis #24
I’m at 6,900’ elevation and we have cold winters. Usually nights are in the 10-20 degrees range, but I’ve seen -25 before. Snow cover is variable and it’s the cold open winters that affect the floricane varieties. If you have snow cover all winter I think they would do better. My favorite primocane varieties are Autumn Britten, Polana, and polski. This company always has new varieties also. They are where I got my plants originally.
Edit: don’t constrain yourself to my recommendations. This company has new releases every year. But I do recommend mid/ late summer or fall primocane varieties.
2024 BOBCAT TL619 TELESCOPIC FORKLIFT (A65053)
2024 BOBCAT TL619...
2018 Ford E-450 Shuttle Bus (A61573)
2018 Ford E-450...
2012 HINO 258A CAB AND CHASSIS(INOPERABLE) (A67714)
2012 HINO 258A CAB...
2012 Mercury 25HP Outboard Boat Motor. (A66738)
2012 Mercury 25HP...
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
2007 FORD F-450 SUPER DUTY BUCKET TRUCK (A67714)
2007 FORD F-450...
