Ram vs Dodge/Chrysler - how complete is the separation?
   / Ram vs Dodge/Chrysler - how complete is the separation? #101
Seems like a silly argument, when both have been working in countless millions of applications, for about 100 years. Isn't the choice of block configuration chosen as much by the available space (eg. motorcycles, airplanes, battleships), as anything else?
   / Ram vs Dodge/Chrysler - how complete is the separation? #102
Mine have been fantastic.
I don't know where that leaves the conversation.
Probably depends on who uses their trucks for what.
Here’s my Cummins in-line six entry.
GCWR about 48,000lbs on this load.
   / Ram vs Dodge/Chrysler - how complete is the separation? #103
It's also the cheapest to build...you forgot that.
Nothing wrong with that.
Cheaper, longer lasting, more torque and longevity????
Sign me up!
   / Ram vs Dodge/Chrysler - how complete is the separation? #104
More internal bearing surface with the V.
More crank bearing support with in line.
Don't need a long stroke to get the same power.
HP? mabes , but I want more torque, not more HP
Can use more of the RPM band.
And consequently suck down more $4/G fuel, so there’s that.
Cooling doesn't have the cavitation issues with a long block.
Are you kidding? 7.3L Powerstrokes were widely known for cavitation.
V motors are best served by a turbo supplying each bank, therefore they can be smaller and spin faster allowing for better low end torque.
Which also means lots more expensive, more air plumbing, more to break and LOTS of width under the hood. Can you say complicated/high cost of ownership?
   / Ram vs Dodge/Chrysler - how complete is the separation? #105
The new Stellantis inline 6 we are discussing will be available with 2 turbos. Each feeding 3 cylinders. Doesn’t matter if it’s a V8 configuration with 2 turbos feeding 2 banks. The turbo doesn’t care about the orientation of the cylinder bores.
The HP, and Ft/Lb #’s speak for themselves
   / Ram vs Dodge/Chrysler - how complete is the separation? #106
The V-heads are a die-hard bunch….
I have never seen an engine configuration disappear faster.
   / Ram vs Dodge/Chrysler - how complete is the separation? #107
The world’s largest engine. A straight-14. Each piston weighs over 12,000 lbs, with a stroke over 8 feet.
Redline is 102 Rpm’s 😃
   / Ram vs Dodge/Chrysler - how complete is the separation? #109
And the really cool thing is with turbo(s) you open up the availability of a exhaust/compression brake.
It’s the turbo that makes the torque, the responsiveness and the exhaust brake.
Everyone wants that.
   / Ram vs Dodge/Chrysler - how complete is the separation? #110
Meh, I've had 12 and 24V Cummins Dodge W250s (93 and early 2000s-might have been be 02). Currently have a 1/2 ton Ram with the 5.7.
You won't catch me anywhere near a newly released engine/transmission combo.
If I need a new truck in the the next 5 years, it will have to be the 3/4 ton with the 6.4 gas in it. Would do Cummins, but it doesn't match my usage and the heck with modern emissions on those things.
NEW Landhonor 5400LB Ratchet Binders & G70 Chains (A59000)
NEW Landhonor...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2017 CAT 315F LCR EXCAVATOR (A58214)
2017 CAT 315F LCR...
John Deere 1025R (A53317)
John Deere 1025R...
2018 Doosan C185 Trailer Mounted Air Compressor, Model 484289UBACG07, S/N C185WD20T4F, Deutz Diesel (A59076)
2018 Doosan C185...
Portable Restroom (A54865)
Portable Restroom...
