Grappling fun - A Picture Thread....
/ Grappling fun - A Picture Thread.... #1,962
This tree was to close to the garden and had to go
/ Grappling fun - A Picture Thread.... #1,963
The deep winter frost here pushes up rocks into the road surface. Every spring there is a new crop. Any that will stop my grader blade or snow plow I pull out. This one only had a knub showing but felt solid. You never know what lies unseen underneath.
Kubota M5640 and FrostBite Grapple.
I took a video just for fun - 5 minutes.
gg
/ Grappling fun - A Picture Thread.... #1,964
@Gordon Gould, those are big rocks. Now you have a hole. I think you need a jack hammer attachment for your tractor, and just make gravel
/ Grappling fun - A Picture Thread.... #1,965
gg
Nice job!!! Find a few more of those and you could build a stone patio.
/ Grappling fun - A Picture Thread.... #1,966
Interesting rock. Around here a rock of that size would be more rounded. That one looks like it was fractured off of a big brother down under.
/ Grappling fun - A Picture Thread.... #1,967
We have all sizes and shapes of rock here. Nothing is what I would call typical. The top layer of earth is glacial till down to about 20 feet and most surface rocks come from that. Below the till is a couple hundred feet of shale bed rock. It has vertical grain from being folded up when a piece that broke off of Africa collided with America eons ago. The Connecticut River is in that fault line and is about 5 miles from here. Where the shale comes to the surface it is either ledge or like this.
The big glacial rocks can be rounded or angular. I have no shortage of them.
gg
/ Grappling fun - A Picture Thread.... #1,968
Gordon, very cool. Interesting lesson in regional geology!
Looks like you have the right tool for this!
/ Grappling fun - A Picture Thread.... #1,971
Ah, finally this thread surfaces again!
After using my Landpride SGC0660, I'll never be without a FEL and grapple again! It makes taking down trees and limbs a trivial undertaking.
Only negative I have to say about it is that the grease zerks came out when I tried to grease it. No biggie, just need to clean the threads up and screw them in tightly.
/ Grappling fun - A Picture Thread.... #1,972
20240430_062722.jpg This pile shows the potential advantage of grapple mounted on forks, vs a conventional grapple. With forks I could flip the logs off the end of the tongs,tossing them to the back of the pile for a taller stack. That would have resulted in it being 8 feet tall all of the way back, rather than just in the front.
/ Grappling fun - A Picture Thread.... #1,973
Pallet forks with a matching grapple is easily the most useful tool I've ever bought for a tractor,
From sorting logs out of a pile,
then loading them on the deck of my sawmill or trailer,
to taking loads of slabs or lumber away from the mill,
to holding firewood logs while they are being cut to firewood length,
to moving/loading all the brush or limb wood,
to moving the boxes of splits to the drying area,
Even prying boulders right out of the ground and moving them out of the way,
and a thousand "other" things they do amazingly well, MUCH more useful that a dedicated grapple.
SR
/ Grappling fun - A Picture Thread.... #1,974
SR
I broke my Titan pallet forks digging a rock out. I can buy a new backing plate but am not a proficient enough welder to make a safe repair.
/ Grappling fun - A Picture Thread.... #1,975
Yeaaa, you have to buy "good stuff" if you are going to be prying, HLA makes some good forks!
You can't buy "price" if you want good stuff!
Take yours to a welding shop...
SR
This isn’t that uncommon. A lot of forks have been bent by trying to use them for digging out rocks and brush/stumps. The owner I bought my tractor from bent my forks doing the same thing.
2011 Caterpillar 420E 4x4 Extendahoe Loader Backhoe (A64194)
2011 Caterpillar...
2011 Kenworth T300 S/A 17ft. Cab and Chassis Truck (A64194)
2011 Kenworth T300...
2R ROTARY HOE, 3PT (A64278)
2R ROTARY HOE, 3PT...
2017 Chevrolet Tahoe SUV (A64557)
2017 Chevrolet...
NEW HOLLAND 352 FEED MILL GRINDER / MIXER (A64278)
NEW HOLLAND 352...
2020 CATERPILLER 326 EXCAVATOR (A65053)
2020 CATERPILLER...
