Trailer recommendation for a New Holland Workmaster 75
   / Trailer recommendation for a New Holland Workmaster 75 #11
Thanks - do you think without any 3-pt that I’d be ok with the big tex 20+5 mega ramps? 20 feet of deck and 5 feet of ramps folded into deck? 5 feet shorter than yours. It looks like there should be ample space based on the pics?
You will have room with an implement. Mine is the Big Tex 20+5 with Mega ramps, for a total of 25' in length. If the implement prevents the ramps from laying flat after getting the tractor pulled up on the trailer, I would just pin the ramps upright. That is what the pin at the bottom between the rub rails is for.
Oh thank you! I was thinking based on your first message that yours was 30’ long, a 25+5.
   / Trailer recommendation for a New Holland Workmaster 75 #13
Anything longer than 22-24’ you‘ll need duals and you’ll be up in the 24k range. Then you are gonna get pulled over for a CDL. My set up allows for me to have something on the 3pt, and still ”look” under 26k…
Why? My D/C is 28' de-rated to 16k from 18k. With my 10k rated 2500 plus 16k trailer I am at 26k.
   / Trailer recommendation for a New Holland Workmaster 75 #14
Well I can't say I've looked into it much so far, but I don't believe that's true. At least not the 'anything longer than 22-24' ' part.
Not sure if I'll even be able to swing a new trailer this year, depending on what the mowing season brings, so haven't been in a hurry to check them out specifically. But I do know that buying a trailer that's too small is worthless. A 22-24' trailer would be pointless for me. No point in buying one at all if it won't fit the configuration I need.
De-rating one would be a possibility I suppose. Tons (and I mean tons) of them running around here with no ICC numbers with the trailer sizes I have in mind. Bear in mind the weights I'm going to be hauling would likely never be over 10k (7k tractor with maybe a couple more attachments along for the ride). This is AG country, and DOT enforcement doesn't really fit the local culture. You could be dragging a trailer on it's side and on fire down the road and LEO's don't give you a second glance. H*ll, even seeing a guy with his load (equipment) chained down is a miracle (especially skid steers-don't know what it is about "skid steer guys" here, but none of them own any chains or binders).
   / Trailer recommendation for a New Holland Workmaster 75 #15
I'm still in the Day Dreaming stage of buying a trailer to haul my stuff around. I still have to buy a bigger truck to pull it!!!
For me, I want to be as close to 20,000 pounds as I can get because that's what the Farm Tags allow. My tractor is 9,000 pounds, the trailer is going to be around 6,000 pounds, and that leaves me 4 to 5,000 pounds for implements.
I measured how from my front tires to the back of my 12 foot batwing, and it's 24 feet. That would be my absolute minimum, but I'm thinking that I want to have 30 feet to be comfortable.
I also want to haul round bales with it. For me, the biggest pain with hauling hay is strapping it down. I don't want to buy a hay trailer, so I'm leaning towards this trailer from Texas Pride with side rails that are 8 feet apart. I think that this will allow me to place the bales inside the rails of the trailer, and haul them without any straps, if I don't stack them.
   / Trailer recommendation for a New Holland Workmaster 75 #16
What I mean is if you get that long with 14k axles, you won’t have any rating left for cargo if you don’t go up to 24k axles. The trailer will weigh 6-7k.
@EddieWalker strapping down takes a couple minutes. I use the few stake pockets or d-rings on mine.
   / Trailer recommendation for a New Holland Workmaster 75 #17
I don't think you can fit 2 4'X5' round bales in between the rails. There is only 6'8" between the wheel wells. Like Stumblinhorse said, strapping down doesn't take long. I put 5,400# WLL d-rings in every stake pocket. My 2" 3,333# WLL straps have twisted snap hooks. That way I can strap the load down by myself without having the far side come loose. If I need something in between I use a 2" 3,333# WLL axle strap around the rub rail standoff support. I switched my 3/8" chains over to G70 hooks with safety latches for hauling equipment, same type hooks that wreckers use for safety chains.
   / Trailer recommendation for a New Holland Workmaster 75 #19
I have a TL80A new Holland with a cab. I do not have a front end loader on it. I do have a twin spindle 96 inch offset Alamo Mower. Actually it’s a rhino mower. I haul it on a big text 25 foot deck with mega ramps for a total of 30 feet. It’s a pretty tight fit. I’m also overweight on the trailer.
I’m not sure the 22 feet would be long enough. Especially if you go to move it with a Bushhog.
My second observation without knowing your age how long will you be able to flip the mega ramps? When I bought the trailer flipping the ramps was no problem. Six years later and having to live in a wheelchair, I struggle with the mega ramps.
I would suggest at least a 25 foot Goose neck and get a hydraulic dovetail if you plan on keeping it for a long time. I know it’s easy to spend somebody else’s money.
Yep, get Longer not shorter. I can't even fit a 5 foot brush hog and my 55 HP tractor completely on a 20 foot and that is with the bucket placed on top of the fifth wheel... Pay a bit more out of the gate and get that extra length.
   / Trailer recommendation for a New Holland Workmaster 75 #20
I like the flat hooks for the most part. I wrap the strap around the hook so it can't come loose, it also provides a more blunt edge v/s the stake pocket when you wrap the hook from the bottom. If you hook at the top and wrap, the strap contacts the sharp edge of the stake pocket.
I also carry 12' and 20' for when the standard 27' has too much excess.
2025 JMR 40in Single Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A50322)
2025 JMR 40in...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A52128)
John Deere 6105E...
Echo SRM2620 Gas Trimmer (A49462)
Echo SRM2620 Gas...
71068 (A49346)
71068 (A49346)
John Deere 893 Corn Head (A50514)
John Deere 893...
Great Plains Nutri-Pro NT-30 Nh3 Applicator (A50514)
Great Plains...
