Comparison Buying my first sub compact tractor need help deciding.
/ Buying my first sub compact tractor need help deciding. #1
Ricanrider
N/A
I bought a farm in Upstate NY, I have leased most of the acres to a nearby farmer, so I'm just looking to maintain the 5 acres around our house. The terrian is flat with some hills. I'm looking to use the tractor for mowing and plowing my driveway along with yardwork/ landscaping projects. The subcompact tractors I was considering were the LS MTl25, Kioti 2520, Mahindra 25L HST and the New Holland Workmaster 25s. I would have considered JD and kubota but there aren't dealers in my area and there also out of my budget. I'm also set on getting a new tractor for 0% financing. Does anyone have experience with these models and which do you think would be the best option. I do like the NH wm25s but I heard LS makes the same tractor.
/ Buying my first sub compact tractor need help deciding. #2
Few here will recommend a subcompact category tractor for use on more than two (2) acres, three acres tops.
BUY ENOUGH TRACTOR​
VIDEOS: https://www.youtube.com/results?search_query=subcompact+vs+compact+tractor+
/ Buying my first sub compact tractor need help deciding. #3
Welcome aboard. Evaluate your current and as best you can - future needs. Choose carefully and buy your fifth tractor first instead of incrementally finding your tractors growing smaller as you become familiar with them.
/ Buying my first sub compact tractor need help deciding. #4
How much of this 5 acres are you planning to mow?
/ Buying my first sub compact tractor need help deciding. #5
If you want to do more than just mow, you should consider moving up to a compact with larger rear tires. The subcompacts small tires compromise the ground clearance and 3 point lift range. Also the tires will wear a lot faster. I don't think it costs much more to move up.
/ Buying my first sub compact tractor need help deciding. #6
Subcompact Ground Clearance:
/ Buying my first sub compact tractor need help deciding. #7
Jeff has given all the advice you need. Most brands are just fine for small areas but size really matters here.
/ Buying my first sub compact tractor need help deciding. #8
I have about 10 acres but only about 2 of the ten is cleared, the rest is woods. I have what I guess is considered a CUT, a Compact Utility Tractor, not a Sub Compact. The tractor is a 44 year old Yanmar and it has a front end loader (FEL). I would not consider anything less. My neighbor has a new Kioti tractor. It is very nice but has smaller wheels and despite it being 4 wheel drive he has had some trouble with ground clearance and getting stuck. My taller tractor is only 2 wheel drive but it doesn't get stuck because of ground clearance issues. You should for sure get a 4 wheel drive tractor but if I was you I would get a CUT. With a front end loader. The FEL makes a tractor way, way, way more useful.
Eric
/ Buying my first sub compact tractor need help deciding. #9
I looked at them long and hard and tested every one of them in my area which is basically the same as yours . I bought a Kioti 2520. I use it for grass cutting and snow blowing.
I did not like the LS or Mahindra they just were a lesser quality build fit and finish and would not buy them at any price.
JD and Kubota were about the same quality but cost 3k more.
I really liked Yanmar, but I didn't like the way the attachments mounted.
Look at the picture of the Kubota above with the steering ram exposed. It's just screaming come nick me so I can leak.
Go look at them and test ride them the differences become oblivious in person.🍻
/ Buying my first sub compact tractor need help deciding. #10
Maybe this will help you to decide what you need:
willy
/ Buying my first sub compact tractor need help deciding. #11
It isn't just about row crops. Hay?
The higher and narrower the tractor, the more tippy it will be, and the lower and wider, the more stable. Especially an issue for hills. So there are benefits of the tiny tire tractors.
It is nice to be able to drive over small debris, but really I'm not driving over super tall stuff. And, it has been a lifetime ago since I plowed with a 2 bottom plow, and driving with one wheel in one of the ruts. Rototilling has different requirements. I've been driving a bit in mud lately, so some extra clearance is nice to keep from getting stuck.
Now, if one is doing a lot of bucket work, and perhaps a lot of forklift work, then there is no substitute for power and weight.
Anyway, there is no one size fits all, and it really depends on multiple factors in the person's environment.
/ Buying my first sub compact tractor need help deciding. #12
Also, if one is doing rough mowing, then look at mower sizes and HP requirements before buying a tractor.
/ Buying my first sub compact tractor need help deciding. #13
Those are all foreign made and comparable, as is almost all scut tractors now. LS and NH are the same. I would pick the closest dealer with the best reputation.
For future reference, Tractordata.com is a good source for info., although the website isn't the easiest to get to know. So, Google search the specific tractor then click on the tractordata link.
/ Buying my first sub compact tractor need help deciding. #14
BUY ENOUGH TRACTOR
At least 30 HP, Check out Yanmar/Branson/ Kioti
/ Buying my first sub compact tractor need help deciding. #16
It's your money, and if a sub compact is what you want, that's fine, but I'll throw my opinions in;
1) consider atleast one of the half size larger than Sub; along the lines of the RK25/TYM25, the Massey 1526, ect. The subs really do have very very low ground clearance, and even for 'yard work' the loader lift capacity is pretty dang low.
2) you said you are set on 0% financing; which is fine; but atleast ask what the payments over the same period of time, at conventional rate would be; it is often the same payment, or lower, because the 0% basically is pre-paymwnt of intrest; IE; $17,500 foe conventional vs $20,000 for 0%.
/ Buying my first sub compact tractor need help deciding. #17
@Ricanrider a good starting place would be; make a list of what impliments you are going ro want to buy at some point. That's gonna go a long way to tell you if a Subcompact will suit you. There are certain things; like a 3 pnt post hole auger that is almost unusable with one; same with a grapple, or pretty much any front or back impliment that weighs more than about 400 lbs. It's not just weight either, it's width/length/height. Let's say you want to do garden stuff; probably can't straddle a raised bed row with a sub.
I'm not the guy to comment on snow stuff; but I don't know how a subcompact would do in 6-8" of the stuff; let alone if you had to go over a windrow of the stuff, or a drift or whatever.
/ Buying my first sub compact tractor need help deciding. #18
Good luck on your search. I too wanted a sub compact tractor. I looked at JD, Kioti, and Kubota. I was pulling more towards Kubota as I already had an RTV. When I took a break from internet searching, and learning. Went to the dealers and the sub compacts just seemed so small. Like what can I really do with that?
So I just focused on the next size up tractors. There was really no downside to it. Believe what others have said about go bigger. I ended up going with the L2501. So glad I did because I found so many other things to get into that the smaller tractors would struggle with.
I also had a third function installed for a snow blade I bought. Then later was glad I did, don't really have the snow blade on, but bought a grapple. That is on probably 75% of the time.
Also keep in mind, if you do buy a smaller tractor, and later want to buy bigger, that can set you back even further. I did the 0% for 84 months. They also had $1000 off if you added an implement on the original sale. A $500 off Kubota day coupon if you went to this open house thing. So I also added the snow blade and the quick hitch.
Took me about 6 months before I realized I needed a box blade and a grapple. They also did 0% for 24 months on implements, so I did that too.
Definitely go out, sit, drive, have fun on your search. Ask for discounts, deals etc. If you are still set on a sub compact, go for it.
/ Buying my first sub compact tractor need help deciding. #19
As several others have pointed out, there is a huge jump in capability between subcompacts and compacts. Not so much in HP, as in the larger frame and weight of the compact. There is another even larger jump between compacts and utility size tractors. Usually that one is both HP, gearing, and frame size.
My own preference on small acreage is not to try to do mowing and tractor work with the same machine.. Choose a compact size tractor with a FEL, and add to that your choice of inexpensive mowers.
/ Buying my first sub compact tractor need help deciding. #20
its not that subcompacts are bad its that the price is so close to a compact that there is very little reason (at least when i was looking), the place where a subcompact shines is if you have some tight spaces to maneuver in, My 5145 is like a bull in the china shop in tight quarters.
2008 FOREST RIVER CARDINAL 30RK 5TH WHEEL (A65643)
2008 FOREST RIVER...
2011 JCB 4x4 Backhoe 3CX14-4-T (A65579)
2011 JCB 4x4...
2023 KOMATSU D51EX-24 CRAWLER DOZER (A65053)
2023 KOMATSU...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
2011 International 4300 Versalift VST60001 65ft. Insulated Bucket Truck (A64194)
2011 International...
2025 Auger Drill Bit Skid Steer Attachment (A64553)
2025 Auger Drill...
