Comparison Buying my first sub compact tractor need help deciding.
   / Buying my first sub compact tractor need help deciding. #1
Ricanrider
N/A
I bought a farm in Upstate NY, I have leased most of the acres to a nearby farmer, so I'm just looking to maintain the 5 acres around our house. The terrian is flat with some hills. I'm looking to use the tractor for mowing and plowing my driveway along with yardwork/ landscaping projects. The subcompact tractors I was considering were the LS MTl25, Kioti 2520, Mahindra 25L HST and the New Holland Workmaster 25s. I would have considered JD and kubota but there aren't dealers in my area and there also out of my budget. I'm also set on getting a new tractor for 0% financing. Does anyone have experience with these models and which do you think would be the best option. I do like the NH wm25s but I heard LS makes the same tractor.
   / Buying my first sub compact tractor need help deciding. #2
Few here will recommend a subcompact category tractor for use on more than two (2) acres, three acres tops.
BUY ENOUGH TRACTOR​
VIDEOS: https://www.youtube.com/results?search_query=subcompact+vs+compact+tractor+
   / Buying my first sub compact tractor need help deciding. #3
Welcome aboard. Evaluate your current and as best you can - future needs. Choose carefully and buy your fifth tractor first instead of incrementally finding your tractors growing smaller as you become familiar with them.
   / Buying my first sub compact tractor need help deciding. #4
How much of this 5 acres are you planning to mow?
   / Buying my first sub compact tractor need help deciding. #5
If you want to do more than just mow, you should consider moving up to a compact with larger rear tires. The subcompacts small tires compromise the ground clearance and 3 point lift range. Also the tires will wear a lot faster. I don't think it costs much more to move up.
   / Buying my first sub compact tractor need help deciding. #6
Subcompact Ground Clearance:
   / Buying my first sub compact tractor need help deciding. #7
Jeff has given all the advice you need. Most brands are just fine for small areas but size really matters here.
   / Buying my first sub compact tractor need help deciding. #8
I have about 10 acres but only about 2 of the ten is cleared, the rest is woods. I have what I guess is considered a CUT, a Compact Utility Tractor, not a Sub Compact. The tractor is a 44 year old Yanmar and it has a front end loader (FEL). I would not consider anything less. My neighbor has a new Kioti tractor. It is very nice but has smaller wheels and despite it being 4 wheel drive he has had some trouble with ground clearance and getting stuck. My taller tractor is only 2 wheel drive but it doesn't get stuck because of ground clearance issues. You should for sure get a 4 wheel drive tractor but if I was you I would get a CUT. With a front end loader. The FEL makes a tractor way, way, way more useful.
Eric
   / Buying my first sub compact tractor need help deciding. #9
I looked at them long and hard and tested every one of them in my area which is basically the same as yours . I bought a Kioti 2520. I use it for grass cutting and snow blowing.
I did not like the LS or Mahindra they just were a lesser quality build fit and finish and would not buy them at any price.
JD and Kubota were about the same quality but cost 3k more.
I really liked Yanmar, but I didn't like the way the attachments mounted.
Look at the picture of the Kubota above with the steering ram exposed. It's just screaming come nick me so I can leak.
Go look at them and test ride them the differences become oblivious in person.🍻
   / Buying my first sub compact tractor need help deciding. #10
Maybe this will help you to decide what you need:
willy
UNUSED FUTURE D680 56" HYD PILE HAMMER (A57193)
UNUSED FUTURE D680...
UNUSED PABREAK METAL COYOTE SHOOTING TARGET (A57193)
UNUSED PABREAK...
Booster Cables (A55852)
Booster Cables...
2020 Terex RL4 Towable Light Tower (A55851)
2020 Terex RL4...
2021 CATERPILLAR 906M WHEEL LOADER (A52707)
2021 CATERPILLAR...
2024 BOBCAT MT100 STAND-ON SKID STEER (A52707)
2024 BOBCAT MT100...
