Massey 1547 hst question on trans fluid and gear range
   / Massey 1547 hst question on trans fluid and gear range #1
moparguy55
Massry fergusson 1547
Hello
1900hrs on my 08 1547 had all new engine oil filter trans fluid and filters.
He out April tdh in it. I see it says meets some massey specs.
Started it hot was on a slight incline in high range and when i went to take off it had a delay. Got to checking fluid and it maybe down a little.
Im thinking i will dump the april tdh fluid and refill with the permatran 821xl.
No manual with it.
When should one use high range ? I have 20acres to disc i assune medium or low range ?
Thanks
   / Massey 1547 hst question on trans fluid and gear range #2
Low range for long hard pulls
High is for roading
   / Massey 1547 hst question on trans fluid and gear range #3
I have a 2007 or so MF1540 HST.
As Dman1981 says above, high range is really just for traveling on a road, with no implements in use. I think I used it once just to try it out.
I use mid range for just about everything
Use low for loader work, brush hogging deep grass, etc.
Basically, start off in mid range, and if it seems to be lugging a bit, put it in low range.
   / Massey 1547 hst question on trans fluid and gear range #4
If you feel/ hear it struggling go down in gear. On my tractor if I can get away with working on mid range I will but more often then not it doesn't, it dose it while it's cold but once it get up in temp I have to switch to low range. High range is very weak it can't handle any resistance just accelerating on a flat surface from a stop position it has a hard time you can ear it wine and you have to ease to it, give it a chance off the start until you get some speed. The oil type wont change that... I personally run Duratran in my Massey only because that's what my local shop (Kioty dealer) has. I can't get my hands on permatran xl even on a online search. As long as it meet the spec, oil is oil espicially for hydraulic oil.
Good to know thanks.
What model tractor do you have?
   / Massey 1547 hst question on trans fluid and gear range #7
Not really but if you think it is, I guess it's ok with you. I never cheap out on any fluids myself, I always use what is recommended, always.
   / Massey 1547 hst question on trans fluid and gear range #8
The Duratran that I use is no cheap by any means, my manual ask for permatran xl try to find some and comes back to me.
   / Massey 1547 hst question on trans fluid and gear range #9
I've switched all 3 of my Kubota's over to Chevron THF Synthetic a while ago and it's very expensive fluid, like almost 200 bucks a pail. Each of mine takes 3 pails to change them, not including filters and each of them requires 2 filters each.
11' CONTAINER (A52706)
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
WINCH CABLE DRUM (A58214)
WINCH CABLE DRUM...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A59575)
2007 FREIGHTLINER...
5004 (A55851)
5004 (A55851)
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
