Massey 1547 hst question on trans fluid and gear range
   / Massey 1547 hst question on trans fluid and gear range #1
moparguy55
Massry fergusson 1547
Hello
1900hrs on my 08 1547 had all new engine oil filter trans fluid and filters.
He out April tdh in it. I see it says meets some massey specs.
Started it hot was on a slight incline in high range and when i went to take off it had a delay. Got to checking fluid and it maybe down a little.
Im thinking i will dump the april tdh fluid and refill with the permatran 821xl.
No manual with it.
When should one use high range ? I have 20acres to disc i assune medium or low range ?
Thanks
   / Massey 1547 hst question on trans fluid and gear range #2
Low range for long hard pulls
High is for roading
   / Massey 1547 hst question on trans fluid and gear range #3
I have a 2007 or so MF1540 HST.
As Dman1981 says above, high range is really just for traveling on a road, with no implements in use. I think I used it once just to try it out.
I use mid range for just about everything
Use low for loader work, brush hogging deep grass, etc.
Basically, start off in mid range, and if it seems to be lugging a bit, put it in low range.
   / Massey 1547 hst question on trans fluid and gear range #4
If you feel/ hear it struggling go down in gear. On my tractor if I can get away with working on mid range I will but more often then not it doesn't, it dose it while it's cold but once it get up in temp I have to switch to low range. High range is very weak it can't handle any resistance just accelerating on a flat surface from a stop position it has a hard time you can ear it wine and you have to ease to it, give it a chance off the start until you get some speed. The oil type wont change that... I personally run Duratran in my Massey only because that's what my local shop (Kioty dealer) has. I can't get my hands on permatran xl even on a online search. As long as it meet the spec, oil is oil espicially for hydraulic oil.
Good to know thanks.
What model tractor do you have?
   / Massey 1547 hst question on trans fluid and gear range #7
Not really but if you think it is, I guess it's ok with you. I never cheap out on any fluids myself, I always use what is recommended, always.
   / Massey 1547 hst question on trans fluid and gear range #8
The Duratran that I use is no cheap by any means, my manual ask for permatran xl try to find some and comes back to me.
   / Massey 1547 hst question on trans fluid and gear range #9
I've switched all 3 of my Kubota's over to Chevron THF Synthetic a while ago and it's very expensive fluid, like almost 200 bucks a pail. Each of mine takes 3 pails to change them, not including filters and each of them requires 2 filters each.
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A59228)
Dvorak Model 3072A...
2013 BUJ (A59231)
2013 BUJ (A59231)
UNUSED IRANCH IRTPL 10000Ib TWO-POST CARLIFT (A60432)
UNUSED IRANCH...
WOLVERINE TQH-26-02C, 3 PT RECEIVER HITCH (A60430)
WOLVERINE...
2022 Behnke Trailer (A55973)
2022 Behnke...
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
