Kubota F series
   / Kubota F series #511
Is the F3990 still in production ?
A dealer here in Georgia said the F3710 has taken its place.
I think that model is toast. Didn’t have the best reputation.
   / Kubota F series #512
Exact same engine, turbo & trans as the newer F3710 replacement.
   / Kubota F series #513
Yeah but the emission system in the 3990 was troublesome. The early models especially.
I have a feeling you might be disappointed in an F if rapid cutting is your goal.
They are not as fast as a ZD. I’d say they are about 1/2-3/4 as fast. I don’t think they ride as good, either.
But if speed is not an issue, then they are ok.
   / Kubota F series #514
The F3710 I ran seemed faster than my ZD1511.
BUT I can’t mow real fast here on rough farm ground.
   / Kubota F series #515
And that’s the difference. Your rough ground will take away what little speed the F offers. The front mower running on its own small wheels can’t run as fast as zero turn deck on bigger tires and “hanging” from a suspension.
If you have rough ground, you have to slow down a lot with an F front deck. The little deck wheels will get swallowed up.
You’d be all set with a ZD and bar tires, but it seems like you can’t see the forest through the trees lol
   / Kubota F series #516
There is the issue of bar tires rutting the ground over time & tearing it up if making "zero-turns", which is why our newer mower has turf tires and is 4x4 capable!
   / Kubota F series #517
I agree arto on bar tires tearing up ground. (y)
I’m no fan with them on a tractor or mower.
I DONT do zero turns tho.
I’m only interested in a 4wd F for a few areas & my steep 800’ long bank.
I totally agree with Hay Dude on the small frt deck tires on F taking a beating on rough ground.
I’ll continue mowing 85% of my farm with big Zero because it’s the perfect match 😻 …. But still needs a wider cut than 72 :LOL:
   / Kubota F series #518
Bar tires only an issue on tight turns.
Straight up/down hills they are the easiest/cheapest way to double your traction.
Assumed Brown Dog only had straight up/down hills.
   / Kubota F series #519
I mow 1/3rd of my bank up & down.
I mow the other steeper 2/3rds i Horizontally.
So frustrating tho if / when I hit a wet spot.
   / Kubota F series #520
With bar tires you could go up/down the whole hill.
I mean just try them. It won’t cost squat compared to a $35,000 F
Craftsman LT2000 42in. Riding Mower (A49346)
Craftsman LT2000...
2018 Toro Sand Pro Bunker Rake (A49461)
2018 Toro Sand Pro...
2004 Ford F-250 4x4 Crew Cab Mechanic Service Truck (A49461)
2004 Ford F-250...
2019 RBR Venturi 380 (A51039)
2019 RBR Venturi...
2010 Case 650L Crawler Tractor Dozer (A50322)
2010 Case 650L...
2022 BANDIT 2550TK STUMP GRINDER (A51242)
2022 BANDIT 2550TK...
