Kubota F series
   / Kubota F series #511
Is the F3990 still in production ?
A dealer here in Georgia said the F3710 has taken its place.
I think that model is toast. Didn’t have the best reputation.
   / Kubota F series #512
Exact same engine, turbo & trans as the newer F3710 replacement.
   / Kubota F series #513
Yeah but the emission system in the 3990 was troublesome. The early models especially.
I have a feeling you might be disappointed in an F if rapid cutting is your goal.
They are not as fast as a ZD. I’d say they are about 1/2-3/4 as fast. I don’t think they ride as good, either.
But if speed is not an issue, then they are ok.
   / Kubota F series #514
The F3710 I ran seemed faster than my ZD1511.
BUT I can’t mow real fast here on rough farm ground.
   / Kubota F series #515
And that’s the difference. Your rough ground will take away what little speed the F offers. The front mower running on its own small wheels can’t run as fast as zero turn deck on bigger tires and “hanging” from a suspension.
If you have rough ground, you have to slow down a lot with an F front deck. The little deck wheels will get swallowed up.
You’d be all set with a ZD and bar tires, but it seems like you can’t see the forest through the trees lol
   / Kubota F series #516
There is the issue of bar tires rutting the ground over time & tearing it up if making "zero-turns", which is why our newer mower has turf tires and is 4x4 capable!
   / Kubota F series #517
I agree arto on bar tires tearing up ground. (y)
I’m no fan with them on a tractor or mower.
I DONT do zero turns tho.
I’m only interested in a 4wd F for a few areas & my steep 800’ long bank.
I totally agree with Hay Dude on the small frt deck tires on F taking a beating on rough ground.
I’ll continue mowing 85% of my farm with big Zero because it’s the perfect match 😻 …. But still needs a wider cut than 72 :LOL:
   / Kubota F series #518
Bar tires only an issue on tight turns.
Straight up/down hills they are the easiest/cheapest way to double your traction.
Assumed Brown Dog only had straight up/down hills.
   / Kubota F series #519
I mow 1/3rd of my bank up & down.
I mow the other steeper 2/3rds i Horizontally.
So frustrating tho if / when I hit a wet spot.
   / Kubota F series #520
With bar tires you could go up/down the whole hill.
I mean just try them. It won’t cost squat compared to a $35,000 F
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A51039)
John Deere 5090E...
2021 Interstate Tiltbed 40TDL 24 Ton T/A Flatbed Trailer (A49461)
2021 Interstate...
2015 Kenworth T400 T/A Vactor 2100 Combination Sewer Jetter Vacuum Truck (A50323)
2015 Kenworth T400...
2017 VOLVO VNM DAY CAB (A51222)
2017 VOLVO VNM DAY...
1998 Ford F800 Water truck (A49461)
1998 Ford F800...
2013 CAT 950K WHEEL LOADER (A50854)
2013 CAT 950K...
