L4850DT Tires
/ L4850DT Tires #1
Iron Brew
Vancouver Island
Kubota b2400 SOLD. Now a Massey Ferguson 285 SOLD. Now a Kubota 50HP
I have a 4wd L4850 Kubota. Present tires are 14.9 R28 rears and 9.5 R20 fronts. They appear to be factory original, but I don't know for sure. I want to go to turf tires, but those are only available in the 13.6 R28's. Major problems, right?
It gets worse. The service manual says 13.6 R28 rears and 8.3 R20's front. So now I'm in a quandary. If it was a 2wd tractor, I'd just throw the 13.6's on. Given it's 4wd, I'm unsure as to what my next steps should be. Any thoughts? Are the front/rear ratios the same and safe to run that way? Trust the manual? Trust the existing tires?
Thanks all
/ L4850DT Tires
Something for you to look at:
willy
Thank you Willy. It states the tire size as per what I'd found in the manual, unfortunately it then goes on (at the "speed 2" heading) to then say "with 14.9-28 tires". I suspect it would be best to use the 13.6 R28's as per the manuals, not the existing 14.9's...
2019 John Deere M15 Batwing Mower (A66285)
2019 John Deere...
2005 Ford Explorer XLT 4x4 (A62613)
2005 Ford Explorer...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
2008 Freightliner Allegro Bay Class A Motorhome (A61574)
2008 Freightliner...
Titan Attachments Forks (A64126)
Titan Attachments...
2019 Peterbilt 567 Quint Dump (A62613)
2019 Peterbilt 567...
