What do you drive for a truck?
   / What do you drive for a truck? #361
   / What do you drive for a truck? #362
I thought z71 was the off-road package also, although I'm a ford guy.
It also might be different in Canada.
Or the previous owner just liked the decals.
   / What do you drive for a truck? #363
Or a bed swap???
   / What do you drive for a truck? #365
They let you order the Z71 package on 2wd trucks for a while. Shocks, skid plates and sometimes a rear locker.
Didn't know that. Thanks for the info
   / What do you drive for a truck? #366
Ditto here. Thank you for passing it on.
I could be mistaken (again), but until a year or so ago was under the impression that the package included lockers on both ends. I was thinking about upgrading strictly for that function, but found that is no longer the case.
   / What do you drive for a truck? #367
Uhhh, I looking it up and that's a truck. A great truck. (y)
Any more pics ?
Here's another photo, but it's not a truck. They called it a wrecker, and with front and rear winches plus the 10-ton (rotator) crane it's a fairly good one.
If THAT ain't a truck then neither is a Kenworth. :D
Most KWs aren't trucks, they're tractors (made to pull trailers, not put things onto), just like my Pete wasn't a truck.
   / What do you drive for a truck? #368
Here's another photo, but it's not a truck. They called it a wrecker, and with front and rear winches plus the 10-ton (rotator) crane it's a fairly good one.View attachment 863447
Most KWs aren't trucks, they're tractors (made to pull trailers, not put things onto), just like my Pete wasn't a truck.View attachment 863448
Yet take the 5th wheel off, put a dump body on either of those... and they become a truck. At the end of the day they perform the same duties no matter what you choose to call them. A rose by any other name...
(After checking to see what forum we're in I will stop at that. ;) )
   / What do you drive for a truck? #369
Yes, much like my Ram 3500 was "incomplete vehicle" until I put the flatbed on it. Now it's a truck, because it has a cargo area (there are DOT requirements for the minimum size).
When I have something other than the bed on it, it's no longer a truck. If there's nothing it reverts back the incomplete vehicle, if it's a camper it becomes an RV.
I learned an awful lot about this stuff when I had that Pete, used as an RV and insured as such, and trying to put living quarters on the back with room for the Jeep behind that.
No dice, so I figured that if I have to have it registered as commercial (this was in CA) I might as well just build a toy hauler for it.
So it stayed a tractor, with no (or not enough) square footage for cargo. But I do have hand trucks (dollies) and such that are indeed trucks.
   / What do you drive for a truck? #370
You mean a road tractor.
THIS is a tractor :giggle:
2006 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51243)
2006 FORD F750 XLT...
CATERPILLAR D6T XL CRAWLER DOZER (A51242)
CATERPILLAR D6T XL...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2015 MACK ELITE...
2003 STERLING ACTERRA 11FT FLAT BED (A51222)
2003 STERLING...
1240 (A50490)
1240 (A50490)
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
