I like to water in a rooting hormone, when I transplant anything. They make a big difference.Thanks, this will be only be my fourth pine and I bought a spot sprayer, but this one is close enough to the house to water from a hose.
Was told with this one to make the mound with mulch, and I know pines like to root down, so will use the BH and shovel to make sure the dirt under it it a bit more broken up.
Do you use any soil amendments when planting?
Rooting hormone can also be used to revive unhealthy plants, like flowers in late summer.
If you have a bulb auger for your drill, bore holes in the ground about 6' deep, about 18" apart, at the drip line each spring, and fill them with some 10-10-10 or 112-12-12.
Biggest thing with pine trees is, they don't like wet feet. So, if it's wet there, you either need to put in drainage, or mound it up.
I planted a small forest, with about 90 trees in my back acre. White Pine, Alberta Pine, and Blue Spruce trees. As well as a few Maples, and Crab apples. It's 16 years later now, and quite rewarding to see it developing as I envisioned.
