dipperstick won't hold posistion
   / dipperstick won't hold posistion #1
mya
b2410 kubota
woods 6500 groundbreaker dipperstick won't hold posistion, was hoping someone could help narrow down issue, not a big deal to pull cylinder and get rebuilt if that is the problem, wasn't sure if problem could be in the control valve.... any input much appreciated
   / dipperstick won't hold posistion #2
So when you lift the dipper up and neutralize the valve it drops? Most likely the cylinder is leaking. Cheapest, first place to look. Resealing should take care of it.
thanks thats what i was thinking but wasn't sure...any idea of a ballpark cost if i pull the cylinder and bring it to a shop ?
   / dipperstick won't hold posistion #4
Depends on what part of the country you are in, but maybe $150-200.
   / dipperstick won't hold posistion #6
Which way is the cylinder drifting, extending or retracting? If retracting it is the valve, if extending could be valve or cylinder seals.
   / dipperstick won't hold posistion #7
Be aware, some shops want to re-bore or hone the cylinder wall! That's a big up charge...
I got bagged for an extra $300 for that one time.
   / dipperstick won't hold posistion #8
I’ve never heard of reboring a hydraulic cylinder. Honing yes. But really, if it is leaking internally and there is damage to the cylinder, you’ll will need to consider replacement.
thanks for your input...cylinder is extendigng,is there any way to know for sure wether its the valve or cylinder?
   / dipperstick won't hold posistion #10
You can isolate the cylinder from the valve If you have the equipment or means to safely support that load while you remove and cap or plug the rod end hose and then let the load sit on the retracted cylinder. If cylinder extends now you know it is the cylinder seals. If cylinder does not move then points towards the valve.
2013 International DuraStar 4400 Service Truck with Crane, VIN # 1HTMKAAN9DH353312 (A54865)
2013 International...
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A52706)
CATERPILLAR 631E...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
(3) UNUSED HAY SPEARS (A52706)
(3) UNUSED HAY...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
2020 Freightliner M2 106 Elgin Street Sweeper Truck (A55852)
2020 Freightliner...
