dipperstick won't hold posistion
   / dipperstick won't hold posistion
You can isolate the cylinder from the valve If you have the equipment or means to safely support that load while you remove and cap or plug the rod end hose and then let the load sit on the retracted cylinder. If cylinder extends now you know it is the cylinder seals. If cylinder does not move then points towards the valve.
great info....thanks again!
2018 Kia Optima Sedan (A55973)
2018 Kia Optima...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
12in Digging Tooth Bucket Excavator Attachment (A53421)
12in Digging Tooth...
2005 Ford F-150 Pickup Truck (A55852)
2005 Ford F-150...
