Just bought a F3060!
/ Just bought a F3060! #1
Steelsoldiers
Charleston, WV
Kubota F3060
Hi all! First post here! I bought a F3060 last night and am working on getting myself more educated on their operation and maintenance. The guy I bought it from owned multiple Kubota machines and seemed to be very knowledgeable about them. He had owned it for a year before buying a newer F series. The original owner was a school system so most of its 1500 hours were racked up mowing around schools.
I have been mowing about 3 acres of hilly grass with a 1974 Cub Cadet 800. It has been a great little tractor, but its relatively narrow chassis and RWD characteristics make it less than ideal on slopes. This F3060 should help me cut more grass faster and safer.
It has a few issues that need addressing in the near future. First, I need to put a seat on it. The current one is usable, but really ragged. I see that Kubota has discontinued the seat. Any good aftermarket sources for seats similar to what's on it? Second, I need to put some rear tires on it as they are pretty bald. Any particular brand of tires better than others for these machines or will any turf tire of the same size work? Lastly, I need to replace the front plastic and headlight assembly. I often mow into the night if I have to do it during the week. Looks like those parts are still available so that shouldn't be too hard.
Here is a photo of it. Let me know what you think and please feel free to share any tips and tricks for these machines. Thanks!
/ Just bought a F3060! #2
My first tip or thought would be is find a good Kubota dealer and call their parts department.
I usually go with Carlisle for tires.
The seat has quite a few aftermarket options. I’d suggest a complete air ride seat as the F series mowers are not the best for smooth ride.
Find all your spindle grease fittings and driveshaft fittings and make sure they take grease. Maybe order a manual for it.
They‘re pretty tough mowers. Mines been solid. Theres a breather on top of the valve cover with a hose attanched to it. Remove it from the valve cover and clean it. They always get wasp nests in them.
/ Just bought a F3060! #3
Going from the cub cadet to a Kubota F....
You'll no longer be "mowing into the night". 😆👍
Congratulations on having a great machine! If you're really into returning the machine to "factory", have your dealers parts guy to check with Kubotas "obsolete parts" dept.
So far I've been able to get everything for my 35? year old f-2000 with the possible exception of the throwout bearing, my memory is foggy on that and it's use is limited to only being used when engaging the PTO.
Last month I decided to add the "creep speed kit" to my M9540 tractor (Kubota). My local dealer told me it was discontinued.
Messicks parts folks searched the "discontinued" warehouse, there were 21 of this particular item there and now there's one in a box on my shop floor!
I tried locally, but they just didn't want to put in the extra effort and I can't say anything but praise about Messicks service.
Thanks for the tips! We do have a local Kubota dealer, but wasn’t sure if they would be helpful on a 20 year old machine. I’ll reach out to them. Everything looks to have fresh grease on it and the seller just changed the oil/filters. I’ll definitely check the breather. I took the oil fill cap off when it was running and didn’t see any excessive crankcase vapors, so hoping the engine is in good shape.
Thanks, Rusty! Great to know parts are still available even if they’ve been discontinued for a while! I hope you’re right that my night mowing is a thing of the past!
/ Just bought a F3060! #7
Some parts may be more accurate.
My local dealer actually gave me the wrong p/n and I ordered and received it (messicks) only to read the installation instructions and realized that it was not for my tractor.
After shipping it back with an understandable restocking fee, Messicks did send the correct unit. So personally Messicks (or Kubotas discontinued parts warehouse) is 2 for 2 with my needs. I'm sure that this is probably more luck and wouldn't count on every part being available.
I wanted the creep gears (actually another "range" in the transmission) for my FAE flail mulcher and my too big 8' wide snowblower that actually needs another 50-60hp than my tractor has!😆
Wow! That’s sounds like quite the machine. My brother recommended Messicks too. I’ll give them a jingle.
/ Just bought a F3060! #10
Is there a way you can find out when the last time the Super UDT hydraulic fluid was changed?
Seller said it was changed at the end of last mowing season. Has maybe 10 hours on it now. How often do you guys change the oil in the rear end. He said that has not been done since he owned it.
/ Just bought a F3060! #12
That should be done.
Iirc it's like a 500 hour item and just takes a couple of quarts (+/-). Easy but just make sure you fully drain it. On my old F I think you drain each gear case behind the wheel. (bevel gear)
I'm pretty sure that's going to be the same on you unit.
I was told that they started out as basically a "B" series tractor turned around backwards (for service tips) if you can't find a maintenance manual.
Thanks, Rusty!
I mowed our property today and I was super impressed with the results. The yard looks like a golf course and it probably took me 1/3 of of the usual time!
Only minor issue I found with the tractor was a leaking input seal in the rear end. I’ll keep it topped off until I get a chance to replace the seal. According to a couple of TBN threads, it’s not too difficult to swap out.
Only major issue I had with the tractor was losing traction on some wet moss and sliding over the hill with all four wheels churning in reverse. Thankfully, I was able to dig out the front of the deck and then drive it right out. New rear tires and a rear weight kit may have helped, but I think ultimately it was just too wet to mow that section.
/ Just bought a F3060! #16
You'll learn it's traction limitations.
It's usually better to find out going up hill and loose traction at the bottom. Anything can go down hill, it's controlling it that makes the difference. (y)
Told ya that you wouldn't need the headlights. ;)
/ Just bought a F3060! #17
As soon as that turf tread fills with mud you're done. I bury my zero turn several times per season next to my steam bank, mostly because I really dislike using a string trimmer.
Unfortunately, the loose moss and mud filled those turf tires pretty quickly, and then I was toast. The bad thing about our property is most of the steep stuff is above the road and it’s even steeper dropping down to the road. I think I need to landscape that section and just stay the heck away from it. I lost my Cub over the hill there once too 🤦🏼‍♂️
My wife and I were both shocked by how quickly it finished the yard and how it cut it better than the old Cub too. I was sort of sad when it was over because I was really enjoying the mow 😂
I was just typing the same thing lol. Those tires turned into slicks on both ends. Thankfully it was a fairly slow slide down the hill so I didn’t tear anything up or eat the steering wheel. I hate trimming those hills too. I try to only do it a few times a season. Makes me want to kill all the grass there and plant some sort of ground cover.
/ Just bought a F3060! #20
Mowing grass after sunset is an exercise in wadding up damp grass under the deck and depositing clumps in the yard, something I never do because the wadded up grass under the deck promotes corrosion, robs power from the motor and generally makes a mess. Far as I'm concerned, putting lights on any mower is nothing but inane.
Just bought an F2880 with a 72" 3 blade deck used from my Kubota dealer. I'd have like to buy a new one, just cannot afford the 'price of admission' and the JD front mount machines are even more expensive.
Far as seats go, there are many options available, Kubota or aftermarket including air ride bases. If I was to buy a new seat, I'd buy aftermarket from a company like Michigan Seat or K&M. OEM Kubota OEM seats are way overpriced in my view. For a new seat and air ride base, aftermarket, expect to pay around 800 - 1000 for it where a Kubota standard (sweaty butt vinyl seat with no air ride) will be almost as much.
If it was me, I'd buy an aftermarket Cordura seat. Cordura is comfortable on your butt and is very weather resistant. Rural King sells them and they are reasonable as well.
Traded in a 2 oar zero turn and I won't miss it. No more oars and no more punishing ride either.
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
JLG E300AJ (A60462)
JLG E300AJ (A60462)
JOHN DEERE 644K WHEEL LOADER (A58214)
JOHN DEERE 644K...
TRI PAC EVOLUTION APU (A60736)
TRI PAC EVOLUTION...
2024 AGT INDUSTRIAL  H13R (A60736)
2024 AGT...
2020 Chevrolet Tahoe SUV (A61569)
2020 Chevrolet...
