Returning batteries for warranty claim
   / Returning batteries for warranty claim #111
I was more concerned that the clamp on the battery post is unable to be secured
Maybe do a voltage drop test from that post to the other end of that cable. A bad connection could definitely cause your symptoms.
   / Returning batteries for warranty claim #112
If my tractor is showing 13.4+ on voltmeter and I have no trouble light on as stated, why would it be alternator?
Voltage is not all you need. You gota have amperage too. I have seen alternators produce 14.0 volts but only 2 or 3 amps. THAT will not charge a battery ! You need to check them both. Also test a battery with the same load as your starter draws . If your starter draws 200 amps while cranking then that's the load you put on the battery. The ONLY true check is to make it do what's its supposed to do not some electronic bull crop meter.
   / Returning batteries for warranty claim #114
NO hole through clamp for bolt?..... Drill a hole and add bolt...
   / Returning batteries for warranty claim #116
East Penn/Deka batteries-NAPA or maybe Parts Plus?
I saw Lowes carry Deka otherwise autoparts store?
The OEM in my Kubota BX23 was by far the best service ever at 14+ years...
   / Returning batteries for warranty claim #120
And just leave a vice grip on the battery lug permanently?
I was thinking of replacing the lug
That was said very "tongue in cheek" because I know you are fussier than that. I do a lot of fixing for farmers and I have seen many lets say interesting repairs.
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
Heavy Duty Skid Steer Post Driver (New/Unused)(Est. Retail Value $4,900). (A59225)
Heavy Duty Skid...
John Deere 5103 (A53317)
John Deere 5103...
2012 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A56858)
2012 Ford F-750...
2016 HYUNDAI Veloster Hatchback (A56859)
2016 HYUNDAI...
48" X 36" ALUMINUM & PLYWOOD ROLLING TABLE (A58374)
48" X 36" ALUMINUM...
