Returning batteries for warranty claim
   / Returning batteries for warranty claim #41
From another Napa article:
I love it when you can use the company's own info against them
I agree with this from some other previous research I have done (this small farm somehow has 35+ batteries scattered about). An automotive battery at 12.0v is almost useless. My rule of thumb is 12.8v is a fully charged battery at rest, without a surface charge present. 12.6v is 75%, 12.4v is 50%, 12.2v is 25%, and 12.0v is...gone.
I have a Midtronics tester and also a clone from Amazon which tests within .1v of my buddy's Snap-on. Worth buying one of these for a commercial operation like Hay-Dude has. And even an old-school carbon pile or resistance type is a good alternative (for a fully charged battery disconnected from the machine).
I personally consider Deka a good choice for my tractors and other diesels, with Interstate a good choice for runner up. There are others, I know.
I also keep maintainers on equipment not in daily use - batteries are just too darn expensive not to...deep cycle an automotive battery a few times and it simply won't come back to 100% even when fairly new...
Without casting doubts on NAPA (I generally like them), someone is not properly trained if they stated a battery at 12.0v is OK. For CCA recommendations, check the operator's manual or a dealer (and go higher).
All just my opinions, naturally.
^^ I agree with you. 12V is not enough voltage.
First time batteries were trouble, I was able to add voltage with my RAM Cummins battery jump start kit and it started. Then I took it to my shop a few days later to begin hooking it up to my baler. Batteries dead. Night time temps around 35*
I used my John Deere jump starter (a big shop unit) and was unable to get her to fire over after about 3 attempts. She was puffing smoke out the exhaust and the engine would very briefly almost start.
I’m real tempted to dump the batteries at their front door and go get a new set from another dealer (they were happy to sell me a new set for $390).
My Magnum had a similar problem. It would crank pretty good, but not enough to start. New set of batteries and it fired right up.
   / Returning batteries for warranty claim #43
Those situations frustrate all of us. NAPA batteries normally have a good rep, but this is not good local service. Truthfully, depends on your parts needs locally and the relationship you need to have with these guys. Maybe an honest conversation with the manager stating some of the material from the NAPA site on batteries might be in order - no need to get mad, just complicates the issue. He would be foolish to lose a commercial customer and have his shop's reputation damaged in the community over something like this (and his losses are probably covered by the chain on warranty stuff). But if they can't read a voltmeter, I would be uncomfortable dealing with them...
I need to copy a photo of the “readouts” they printed for me even says “good” on them…
   / Returning batteries for warranty claim #45
I used to be an Exide guy for batteries, but recently swapped my supplier to Deka. Deka has a remarkably strong track record from all studies ive done, and i got tired from all the acid spilling from the caps on the exide.
Deka are sealed batteries.
I only installed 57 batteries last year, so not a large dealer by any means. But i dont like getting calls at midnight during a stormy power outage with customer saying their genny isnt starting. I need stong, reliable batteries.
from my own experience servicing generators, the Napa batteries have been pretty nice units, pretty dependable. The Napa brand comes from East Penn mfg, just like Deka units. The batteries i have most problem with have been Wallmart branded units. Its amazing how many year old batteries i end up replacing that say Everstart……. Just saying from my experience.
i had installed a brand new set of Interstate batteries in my F350 and only got 2 years use out of them. i also replaced the tractor battery with interstate battery, and that failed in 1 season. I replaced the tractor battery under warranty, as i got that one from Costco. The ford batteries i replaced with Napa batteries. Well see if they last longer. Interstate used to be a good battery. I have my doubts now.
   / Returning batteries for warranty claim #46
It might depend on what threshold their store sets on the machine as acceptable. It will obviously be something lower than 100% (but how low is acceptable?). Midtronics seems to be the gold standard for professionals, but I suspect any electronic device can get out of calibration.
I know you've got chargers in your shop. You might charge both of the batteries overnight, put a slight load (maybe a 12v headlight) on them for a moment to deplete any surface charge, and then read actual voltage with an accurate voltmeter. That's a good starting point, even without the Midtronics type of tester. If the two batteries are different markedly in voltage, then one battery is pulling the other down (and also lessening the life of the good one). Then just for grins, put an old fashioned resistance clamp-on tester and see if they fall out of acceptable ranges on a 10 second draw. And, if these are not "closed" cells, a battery hydrometer could be used to check specific gravity (which means I'm old...)
One thing to ease the pain, you're probably just going to get a "prorated" refund even if these are bad. Remember that you start the clock again on good batteries...warranty and life. At least that's what I tell myself as I shell out $350+ for a couple of new batteries, LOL.
   / Returning batteries for warranty claim #47
I agree with all this from my limited (sort of) experience. Deka is in my Generac and all equipment that's "important" around this farm. And I don't care what Consumer Report says, Walmart Everstart batteries are just nowhere close to their equal.
   / Returning batteries for warranty claim #48
This is aveage:
NAPA should have a unit to check to see if the battery
is really good by putting a load on it:
Your alternator wll generate around 13.8 - 14.4v, typically at or just above idle.
willy
I have a gizmo I plug into 12V accessory socket that measures voltage. When the batteries were brought back charged overnight at Napa, they read about 12.2-12.4 in the tractor not running. Those would be about dead in my book.
They would turn the starter over fairly well, but as most of you know, diesels need to achieve a certain minimum starter RPM before the engine will fire. She had heavy black smoke at the pipe and wanted to fire, but I think the batts are too weak.
I’m moving on and getting a set of proper batteries. I think there’s a NAPA 1000 CCA model available with same dimensions. We have an independent battery dealer near us that moves a lot of fresh Interstate batteries, too.
   / Returning batteries for warranty claim #50
Is there another NAPA store to try out within a reasonable distance. I'd be curious to get an opinion from different people in the same company. Wouldn't mention the try at the first NAPA store to them though.
34" X 94" X 60" METAL STORAGE RACK (A58374)
34" X 94" X 60"...
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
2006 Ford F-750 Terex Commander C1017 Digger Derrick Truck (A55973)
2006 Ford F-750...
1993 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
1993 Ford F-250...
(INOP )JOHN DEERE RIDING MOWER (A58374)
(INOP )JOHN DEERE...
2012 LEDWELL 48FT DOVETAIL TRAILER (A58214)
2012 LEDWELL 48FT...
