Wont idle down
/ Wont idle down #1
tippydog
Mitsubishi MT272D
My Mitsubishi diesel tractor, MT272D, won't idle down, can't seem to find the problem
/ Wont idle down #2
If it’s running away, cut off the air or fuel..
The problem could be in the injection pump.. it’ll need to come up and out..
/ Wont idle down
What do you mean when you say come up and out
/ Wont idle down #4
I’m thinking it’s a PFR injection pump..
It bolts down on its 4 corners in its own housing..??
You should do some research before trying to get it out..
/ Wont idle down #5
I've looked and looked, and then went to the official Mitsubishi records. There is no MT272 machine listed.
I was once a moderator of the Yahoo Mitsubishi-Satoh group and never came across a MT272.
There is a S372 and MT372.
This is from the official Mitsubishi documented model releases. I snipped the area where a MT272 should be listed.
Even under the other M model designations, no 272.
2015 CHEVROLET CAPRICE (A66091)
2015 CHEVROLET...
2012 CTS BELLY DUMP (A67714)
2012 CTS BELLY...
2013 Lincoln MKX SUV (A66738)
2013 Lincoln MKX...
RIDGID AIR COMPRESSOR (A68842)
RIDGID AIR...
PALLET OF FLANGE CUT-OFF VALVES (A68842)
PALLET OF FLANGE...
2015 CAT 730 (A68134)
