4570Man
Super Star Member
- Joined
- Apr 7, 2015
- Messages
- 18,892
- Location
- Crossville, TN
- Tractor
- Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
The CDL law isn’t hard to understand although apparently it is. It’s simple math. Trailer GVW plus truck GVW. If it’s 26,001 pounds or more you need a CDL and if it’s less than 26,001 pounds you don’t. There’s a ton of rumor about 10k rated trailers and it’s largely wrong. The only difference that makes is the distinction between a class a and class b CDL. You can hook a 14k rated trailer on a 3/4 ton truck that’s GVW is 9900 pounds and pull it across the country without issue. If you upgraded to a 17k trailer you’d have problems or if you hooked the same 14k trailer on a dually that’s frequently rated at 12,500 or slightly more you’d also have problems
