Foton FT254A clutch and parts
/ Foton FT254A clutch and parts #1
Double J Ranch
Foton 254A
Buying a 9/2005 Foton FT254A sight unseen except for a few pics. I'm told it needs a clutch. Very limited info online that I have found. I did purchase a parts manual but can't find a service spec manual or online English resources.
I see there are 2 clutch options for parts. A single stage or a dual stage clutch.
I would like to locate the parts before I drive 6 hours to buy this tractor from a friend that got it from a friend and doesn't have any information on it. I'm told it will go forward but not up an incline.
I know nothing about the Foton brand, but the price is right if I can source the parts.
How can I tell from just the make, model and serial number tag if it has a single stage or a dual stage clutch?
Any help is appreciated in learning this machine, locating a parts dealer and knowing just what I'm dealing with.
Thank you in advance.
Model FT254A
CODE TE 254-C161Q2K
9/2005
ENGINE- YANGDONG Y385T DIESEL
18.4 kW 2350 r/m
Y50700990
-22
12/1999
/ Foton FT254A clutch and parts #2
It is probably a re-branded Jinma.
Check with Affordable tractors dot com or Circle G tractors dot com. They have parts and illustrations online.
The clutch may only need adjustment.
I don't think there is any way to tell what clutch it has by model and serial number. Their parts lists don't work that way. You have to "get eyes on it" to know what type and size it is.
If it has a manual PTO, odds are it has a two stage clutch.
Have a look at the documents here: Harnerfarm Jinma 284 maybe they will help
Thank you so much for the great feedback. I was about to pass on a getting this tractor due to a lack of information. I will definitely try to adjust the clutch first with this new information. I knew about Affordable Tractors site and was very happy that they had the parts manual that I so desperately needed. They were very quick to ship me the right one. I will use them again. I didnt know about Circle G but I do now. Again thank you as I was loosing faith. Im sure this wont be my last question. I enjoy reading the posts here.
/ Foton FT254A clutch and parts #4
Take some pictures as you go through the adjustment and post them here along with an explanation.
It will help others in the future.
Best of luck and don't be afraid to ask more questions.
Great idea. Sounds fun. Will do in a month or so after I go get the tractor.
Thanks
/ Foton FT254A clutch and parts #6
Fotons are not a rebranded Jinma.
SOME of the parts are close or the same, but not enough to use most Jinma manuals.
I have a 206 Foton 504 and have several threads on them for different things.
They are a division of Lovol tractors from China and were very inexpensive when they hit
North America.
They are common under the Lovol brand all over Europe, Africa and South America, and Australia.
Manuals are VERY difficult to find as far as "vehicle specific". But there are general, often
the same, or close diagrams available.
Lots of updates since yall put me on the right paths. And thank you very much.
My tractor is badged-
Foton Europard, model FT254A, Code: TE 254-C161Q2K, 25 HP, Date 9/2005 on the side of the dash. The motor is a Yangdong Y385T 3 cyl Diesel, Date: 12/1999, Engine # Y50700990, Order # -22 China Yangdong Co. Ltd, 4- wheel drive
The American made Loader is a Koyker 140 with the quick detach bucket.
Disclaimer: My Foton 254A seems to be older than most I have seen parts manuals or service manuals for and I am having to wing it using the newer models as a reference so if anyone has an accurate manual or parts manual please advise.
Many of the newer models than mine use the same parts but some parts are different. Don't get me started on the engine oil filter JX0707 that comes in at least 2 different styles but have the same part number. Very little info out there mentioning style 1 or style 3.
It took the knowledgeable Circle G Tractor parts to figure out I needed style 3. Its ID threads were a little different and the face with the holes in it was more convex than style 1. No idea if style 2 even exists or why you wouldn't give a different part number.
Affordable Tractor parts in Texas has also been a very good resource for both information and great parts service. I have now ordered many parts from both and 100% satisfied. Especially for this Unicorn.
This is my first attempt to try and send attachments so bear with me please.
I have several topics to share updates on. I will first try to continue the Clutch thread then maybe repost under other topic threads for the power steering saga. Not great at uploading the images yet.
I ended up having have a Two stage adjustable clutch and not a single stage.
I took the loader off and the mounting R&L towers that bolt up to the side of the transmission.
The left side didn't give any clutch access as its sealed off. It was all done through the access hole on the right after removing the 4 side bolts and 1 underneath.
Used thin metric wrenches to reach in and unlock the nut on right and then turn the square stud to make the adjustment. Counted how many turns, bumped starter and used a ply bar to rotate to the next 2 studs. Mark each as you do it and write it down. If I recall correct, I used numbers 1-3 for the clutch and letters A-C for the PTO adjustment as I indexed it. Had to use a bright head lamp to see the clutch finger gaps as they get closer to the throw-out bearing face. I just used a visual guesstimate to replicate the gap for all three fingers for the clutch then again for the gap to the throw out bearing. I over adjusted the clutch at first and had to back it off because it wouldn't disengage at the end of the clutch pedal stroke. There are a couple helpful U tube videos on adjusting this but not many.
I had someone push the clutch in and out for me so I could see the throw out bearing move back and forth. For clarification it was the pto clutch adjustment that I over adjusted at first causing the pto to stay on even when the clutch was fully depressed. I backed off the adjustments I made and the pto would stop spinning with full depression of the clutch. Im sure a tech would set the clutch and pto way better than I did and know how to get a feeler gauge between the throw out bearing and the clutch fingers, but it is now usable. Before I was thinking it needed a full case split and clutch replacement because it would barley move in 1st gear.
The info I have read states that this tractor will need periodic clutch adjustments to stay working.
So, I assume I will only be able to do this a few times before it does require a case split.
Anyone have feedback on that or any part of this please chime in?
The thin wrenches I used for the clutch were 8mm and 16mm, the ones for the PTO adjustment were 13mm and 14mm.
On both, you loosen the lock nut, make your adjustments then retighten the lock nut before you finish up. You don't have to tighten the lock nut each time you advance to the next one but just don't forget to check and recheck them all before you're done. It's easier said than done at times in a very tight space. Get comfy because everything is done in many very short turns and indexing of the clutch housing.
2014 Dodge Ram 4500 Versalift Bucket Truck (A60352)
2014 Dodge Ram...
2004 CATERPILLAR 416D BACKHOE (A60429)
2004 CATERPILLAR...
1998 Chevrolet Step Van Food Service Truck (A59230)
1998 Chevrolet...
2013 CATERPILLAR 336E L (A58214)
2013 CATERPILLAR...
2015 Ford F-250 Pickup Truck (A59230)
2015 Ford F-250...
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A59823)
2015 GENIE...
