What have you done to your Branson today?
   / What have you done to your Branson today? #1,611
almost put it on its side. decided the fence would be easier to fix than flipping the tractor upright. Colorado blizzard, about 1.5 feet of super heavy snow. mfwd on, chains on rear tires. hit a drift with rear blade and it spun the front off the side. slid down sideways fast. maybe 6 feet of drop at a 30 degree angle to the creek in the bottom by the trees. took out 2 t posts and a bit of paint on the side of the loader and fender rubbing the wires did not hit any hoses or wires with the t posts underneath.
Wow! Nice quick thinking. Glad it worked out for you.
   / What have you done to your Branson today? #1,612
They always tell you to turn into a spin right? ha.
this snow is some of the wettest I have every had to deal with. it's the same density as the mud below it. changed my strategy to straight blade and backing up to plow the actual steep part of the road, taking short runs and pushing off the slopes.
   / What have you done to your Branson today? #1,613
Friendly reminder for today: Check the condition of the hydraulic pumps suction hose friends.
I don't think mine cracked all the way through yet but it will happen eventually. Probably won't show as leak either since it's under suction.
Your unit may also have a return hose down low near the rear transaxle and filter.
   / What have you done to your Branson today? #1,617
The other end of the suction pipe has a short straight piece of rubber hose. For the lack of better pictures at the moment, here is an older one from when I was building the loader. Note the hose in front of the hydraulic filter.
I believe the reason mine is going bad on the pipe side is because some time ago I tweaked the pipe, put a decent kink on it too. I pulled it out to get it straight again but couldn't quite remove a twitch on the 90 degree bent up top. So it kinda forces the rubber hose a little bit out of place.
   / What have you done to your Branson today? #1,618
It's nice to see Branson didnt paint over all the filters like other brands
My filter/return design is different. My filter is located near the LR wheel and there is a short 90 hose to the axle housing, and a short straight to the return pipe. My 90 is more vulnerable to damage than your system if I ride over a small sapling and immediately back up.
The straight hose to the plastic tank on the right has the same vulnerabilities.
2007 FORD F-450 SUPER DUTY (A58214)
2007 FORD F-450...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56858)
2016 AutoHauler...
Chevrolet 2500 Flat bed (A56435)
Chevrolet 2500...
2003 Big Tex 10PI...
2017 Chevrolet Trax LS SUV (A55973)
2017 Chevrolet...
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
