shooterdon
Super Member
- Joined
- Nov 24, 2012
- Messages
- 5,333
- Tractor
- 2019 LS XR4140 HST Cab; 2025 Moto UForce 1000; 2021 Bad Boy 54" ZT Elite
Interested in seeing how people suggest getting a rope up there and tying it off. I have no clue.
I was an arborist for 20 years. That is called a throw line and there are several options available. The line is somewhat stiffer and slicker than paracord and is available in a variety of diameters. The weight is usually an 8-16 oz cordura bag with lead shot in it, although there are also hard rubber balls available. As the name implies, they are typically thrown into the tree, but there are other options, the most popular of which is a device that resembles a large slingshot that is braced against the ground. The use of a bow to set lines is very unusual and is almost exclusively limited to recreational climbing in the very tall conifers of OR and CA.In the arborist world, that is called a Throw Rope. It's a paracord with a weight on the end that you throw up in a tree or shoot up in a tree and then use that to increase the rope diameter to yank the limb out. They also use it to set their climbing ropes so arborists without hi-ranger equipment that have to physically climb a tree.
With it being the tree tops, it's going to be very difficult to throw the bag where you want it and hoist the bull rope up where you want it. Every nearby tree branch could snag the throw line.
It's a reasonable concern whether pulling will do more harm than good.
If the crowns are broken off like the tree in this picture there is no saving it. It might live for a while but the other trees would benefit more from its removal. However, its removal can be challenging.Lots of them that look like this. They are most all maples that cracked off branchings at the crown. They are in areas we use. I'm thinking a long rope tossed up, tied and tethered to the tractor a good distance away. Then see if I can pull them off and down. This is just one, I have about seven others that look the same. I could just cut all the trees down, but I want to save them. None are near utilities or structures.
That is correct. Those maples may last for a while, but they'll never be strong. Red maples are kind of weed trees anyway. They're weak, but can live a long time while rotting and falling apart. You'd be better off thinning them out considerably and letting your pines fill in.I'm coming around, that most likely, these maples are never going to recover in the way that they broke down under the ice load. They tore apart with long vertical fractures making all these widow makers. The conifers survived much better. They just dropped certain branches with clean breaks off the trunk.
The state is finally working on all the dead ash trees, along the state roads, here. After some big winds the other day, I find I have a pine tree in my grove broken at the ground and leaning/hung on another (has been dead for several years). I'll wrap a long strap around the base and drag it down with my tractor. I'm afraid to walk under it now...One could start an entire business here just taking down and cleaning up dead Ash trees.
Ever heard the phrase "what goes up, must come down"? Those bullets are coming down somewhere. Couple years ago, back where I used to live in Ohio, a guy fired his muzzleloader into the air to clear it and killed a kid a mile or so away.Our best option is to get out an old Mauser or other surplus rifle and several boxes of surplus ammo and start blasting. Lots of fun. Mauser is a bit better penetrating than a Mosin Nagant with factory loads with our experience.
I've done that for years. Bought a CHEAP fiberglass bow and a few arrows and shoot fishing line over whatever. The fishing line is still on the pole. Then Masons string, then 1/4" paracord, then 1/4" aircraft cable and lots of it. When you do get to pulling on that cable you don't even want to be in the same zip code.Use a bow and arrow. Tie a small long rope to the arrow, get it over the branch, and then pull a larger rope as required to attach a larger rope.
