Power steering Ford 545
/ Power steering Ford 545 #1
Circle S
Ford 545
I have rebuilt power steering pump and steering column and still will not turn what what could be my problem?
I have not put a pressure gauge on it yet. Ford 545
/ Power steering Ford 545 #2
Welcome to TBN.
Hard to diagnose without knowing pressure. Is oil circulating (is the gear engaged on the shaft)?
Pressure relief adjusted too low/stuck?
Rebuilding meaning installing a seal kit, but how much wear on the pump was there or why did you reseal? Was it working before?
/ Power steering Ford 545 #3
you've cycled it long enough to get all the air out of the system? And kept it topped up while doing it?
I have replaced the power steering pump bleed all the lines. The pressure is 1100. I'm at a loss.
/ Power steering Ford 545 #5
It is an early 545; 78-85? How did you check the pressure on the pump, by dead heading it?
I'm pretty sure, I'll check on this, that the pressure on the pump is supposed to be about 2100 psi and would explain that if your pressure reading is on the pump itself, your pump either is worn out or the relief in the pump is stuck or needs adjusting.
Gleaner Chaffer (A63117)
Gleaner Chaffer...
2018 Chevrolet Trax SUV (A59231)
2018 Chevrolet...
2018 JOHN DEERE 60G EXCAVATOR (A64279)
2018 JOHN DEERE...
New - Front mount rototiller
New - Front mount...
EZ Trail 3400 (A63688)
(1) UNUSED 31X13.50-15 TIRE W/ 6 LUG RIM (A64280)
(1) UNUSED...
