You Know You Are Old When
/ You Know You Are Old When #1,282
Old when:
Your eye doctor refers you to a cosmetic surgeon for a eyebrow lift. The weight of your southbound brows are causing eye irritation and restricting upwards vision.
I’m melting 🫠 and beginning to resemble a bloodhound.
Both of my parents had that done.
/ You Know You Are Old When #1,283
Old when:
My eye doctor was complaining about my face sagging, too.
/ You Know You Are Old When #1,285
Kinda always believed in wearing safety glasses after that
I think about that a lot when working around the tractor. Mainly when hooking up the grapple, but anytime there's risk of getting hydraulic fluid spray.
/ You Know You Are Old When #1,286
And with old equipment that could be anytime it's under pressure when a hose could leak.
/ You Know You Are Old When #1,291
Jeff, how right u are.!!
I rarely used safety glasses when using my wire wheel UNTIL a single wire shot out and stuck in my lower eyelid.!!
If I had held my head just an inch lower, it would’ve caught me straight in the eye ball.!!
I put them on religiously now..
I wear them so much, I forget to take them off.. lol
I seldom wore safety glasses because they made my regular glasses fog up and paid for it when I got a sliver of steel in my eye while drilling. Now that I have implanted lenses that came with the cataract surgeries, I get by with just the safety glasses.
/ You Know You Are Old When #1,292
I wear glasses and always had that fogging issue in cold weather. I bought a clear face shield to wear for grinding and metal work. No more fogging.
/ You Know You Are Old When #1,293
My regular glasses are ANSI approved, although I don't use the side shields. I wouldn't consider trying to fit another pair over them. I do have a screen on my hardhat.
I’m not always great on the use of safety equipment —- but the one thing I always have are glasses and hearing protection.
Once I stopped working as an accountant, my eyes have actually gotten better. I no longer need prescription lenses for close up work.
/ You Know You Are Old When #1,296
You know you’re old when you remember being taught, work hard and you’ll be rewarded.
My kids are still taught that, and in fact I'm pretty sure they work harder at school and other productive things than I ever did, at their age. I'm a lifelong workaholic, but have always had a problem with choosing projects more for interest or fun factor, than profitability.
When you're staying up to 3am to put those new headers on your big block, you're working hard, but not profitably. :D Now most such endeavors and follies involve creating a home and property for my family to enjoy, which is all hard work, but equally unprofitable.
/ You Know You Are Old When #1,297
Rather than leap into projects ballz to the wall you try and prepare and plan accordingly.
/ You Know You Are Old When #1,299
When you’re swapping tires each season on your car, and after doing the second wheel, you start to attempt to justify stopping there…..thinking that it should work fine with two different kinds of tires on it……
/ You Know You Are Old When #1,300
Probably could get away with it on a 2WD vehicle, might not be so good an ide on 4/AWD.
2016 Ford F-150 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
207273 (A52708)
207273 (A52708)
MARATHON 25KW GENERATOR (A58214)
MARATHON 25KW...
2015 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A59230)
2015 Freightliner...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
2012 BIG TEX PIPE TRAILER (A58214)
2012 BIG TEX PIPE...
