My YM186d
/ My YM186d #21
I have been told that the spline couplings are uncommon sizes and hard to source. But getting one fabbed up is looking like my only option currently. I know a guy who could do it but it would mean leaving the tractor with him for months as he takes so long to get round to getting things done.
If i could find the couplings i would have a go at fabricating one myself. But i have no idea how i would match the couplings up which i need.
The original piece broke as it was seized in 4wd and someone has forced the lever to try and select 2wd. It isn't a very strong design
Hoye lists that shift fork lever at $35.00, Yanmar Part No. 194305-22830 as "used shift fork lever". Their item no. is 409714.
/ My YM186d
Thanks yeah i have looked on their site but it says it is not available online. ive tried to contact them before about the drive shaft but they dont reply to me. Maybe because i am in the UK.
If i could find a picture of the part it would help me repair what i have.
/ My YM186d #23
You should be able to measure the diameter of the small rod that broke off and weld a 1 1/2" long piece of hard rod onto it. Then keep gradually making it shorter until if fits perfectly.
/ My YM186d
Yeah i think thats the plan. Then i just need to try get a driveshaft.
/ My YM186d #25
Item-6 sure looks like a clevis pin. If you could take some measurements on what space it fits into, you could order one and then if needed turn it down to size.
Order from McMaster-Carr their customized pins like it or something close enough.
McMaster-Carr
These standard types are at a great price too,
/ My YM186d #26
What is exactly broken on the drive shaft that can't be repaired. Is it the joints or the spindle get damaged beyond repair. A machine shop could make another worst case? I'd check into that.
/ My YM186d #27
McMaster-Carr
Yes, it is exactly like a clevis pin. But it has a short length of hardened rod welded to the end that extends over into the slot on the shift block.
It was the rod that broke off.
/ My YM186d #28
I do not know the size of these parts.
With the clevis pins, some have a threaded base at the bottom. A person can then screw on a rod to the base. From there you would have a working part for your machine. McMaster-Carr has parts like that in the links too. Maybe some options to try.
/ My YM186d #29
I've noticed the broken shaft stub and the one noted as #6 in the pic don't really match up with the trip pin facing 2 different directions.
/ My YM186d #30
I would keep trying at Hoye, though suppliers in Europe may be cheaper. There are a variety of splines on driveshafts, and yes, there are some that are more common in Japan than elsewhere, but they aren't unobtainable, at least in my experience. I would start with the number of splines, diameter, and work from there. Once you have the ends, the drive shaft is pretty straightforward. Again, I suspect that you have more than a few quasi local fabricators that could do the work. I've been impressed at some of the work coming out of Yorkshire and Cumbrian fabricators.
All the best,
Peter
/ My YM186d
All the best,
Peter
Hi Peter which cumbrian fabricators are you refering to as thats where im at.
/ My YM186d #32
I would have to dredge back through some old threads. My primary person I was thinking of seems to have retired. Let me do some poking around to see if I can find some others. But in the interim, Cumbria/N. Yorkshire has lots to choose from. Please be mindful that I haven't used any of them.
If you run out of luck, I hear these folks supply all manner of drive shafts and may be able to put one together.
I would be tempted to talk to custom car fabricators, and naval repair folks, and those making repair to trucks once you have the spline size/number of teeth.
All the best,
Peter
/ My YM186d
All the best,
Peter
J&R replied this morning with only "we cant help you"
Ive messaged a heap of drive shaft and prop shaft manufacturing places and tried Hoye tractors again, the place which has replaced them just said i need to contact Hoye.
/ My YM186d #34
What is it that makes the shifting so stiff? Even with the front axle jacked up, tires not touching anything, shifting that (on YM186D) feels so stiff that there is risk of breaking that pin.
Is there any way to lube that without major disassembly?
/ My YM186d #35
And related... It might as well go in this thread for someone to find in the future:
10 years ago on a prior YM186D I replace the u-joint at the front of the propeller shaft. I learned that is a rare u-joint, difficult to find. But it had one application, that led to various suppliers.
Here's my notes I wrote at the time:
These ATV U-JOINTS WILL FIT THE FOLLOWING​
HONDA ATV models:​
1985 ODYSSEY (FL350) REAR SHAFT​
Part # ATV300​
* These may fit other Arctic Cat models.​
And that guy wanted $249 for it.​
Or see on Ebay under $50.​
American CV​
1985 ODYSSEY (FL350) Rear Axle Shafts Standard U-Joint​
Price: $29.95​
And someone posted in a Honda forum that Honda used that u-joint for only a year or two because it was used at such an extreme angle that it was a frequent warranty repair. No other known applications. [to those Honda enthusiasts].​
EDIT, UPDATE, 2024.
Looking on eBay today I see this U-joint is now also listed as:
Universal Joint-U-Joint GMB 220-0045 fits 74-78 Nissan B210, $18. [so it should be widely available].
Then the application notes say the original driveline used non-replaceable staked u-joints.
Also some of the more expensive listings include spacers and clips, while one commenter said he had to find suitable clips elsewhere. (For his Honda application?)
YMMV. The kit for Honda that I bought, fit perfectly. As I recall, I re-used the original clips.
/ My YM186d #36
@beankp60 Any luck?
These folks do lots of custom driveshafts in the US, and not just for off-road;
All the best,
Peter
/ My YM186d #37
@beankp60 Any luck?
All the best,
Peter
Peter, a really nice find. (y)
FYI, use their measurement page to determine how to specify what lengths you will need with the interfaces!!!
(y)
/ My YM186d #38
(y)
Thanks, and I hope it is useful to others. To be clear, I only know them through others who have bought unique driveshafts from them, and all of them rave about them.
All the best,
Peter
/ My YM186d
That looks a great site post above i will have to check it out.
For a bit of an update. after all the places i emailed i think 2 of them replied to say they couldnt do it.
But i found a guy on facebook selling a ym186 engine and parts. i messaged him saying i would buy everything off him but he was extremely hard to deal with. in the end he said he would just sell me the front axle with the driveshaft but then he became very awkward so i never managed to buy them from him. i left it a few weeks and messaged him on my girlfriends facebook profile and it wasnt easy and took a while but the front axle and drive shaft have shipped and i should be receiving them on Tuesday!
Also i was gardening around where i left the tractor when i first bought it and i found what looked like it could be the snapped off part of the shaft which engages and disengages the 4wd! I cleaned it up and while i had the welder out i put some tacks on it, refitted it to the tractor and my machine is now selecting 4wd and 2wd easily! I can see the end of the output shaft turning when in 4wd and not turning when in 2wd. So when this shaft turns up next week, so long as it is in decent condition it should just be a case of fitting it and then my machine will be sorted.
I will get some pics when the parts turn up. Fingers crossed ive got this issue sorted! If in the future anyone ever gets a batch of shafts made up i would still likely order one as a spare just incase.
I almost forgot, i got in touch with a local guy who has a ym186d but he used to have 3 of them many years ago and he bought up a dealers stock when they stopped working on the ym186d's which the council owned and he kept them going and did the maintenance on them. I have bought all these genuine Yanmar parts all new old stock in the bags. it should help keep mine going for a while yet.
2024 Scag Cheetah 61in. Zero Turn Commercial Mower (A61567)
2024 Scag Cheetah...
UNUSED SDLANCH REMOTE CONTROLLED DUMPER TRUCK (A62130)
UNUSED SDLANCH...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
John Deere Mirror and Light Kit (A63116)
John Deere Mirror...
2008 Kawasaki ZX1000 Motorcycle, VIN # JKAZXCE1X8A013733 (A61165)
2008 Kawasaki...
2023 Ford F-350 4x4 Flatbed Truck, VIN # 1FTRF3DM5PEC15665 (A61165)
2023 Ford F-350...
