Log Hauler
/ Log Hauler #1
HawkinsHollow
SE TN
Branson 3015R
I need a way to move logs to the sawmill. A buddy of mine runs a scrapyard and got this propane tank hauling trailer in. I began to wonder, how would that work as a log hauler. Now I am not talking about huge logs, but 2 or 3 15-20" pine logs winched up and then set down on cross beams to head down the road. Seem like it would work well to me. No machinery needed in the whole process, that is a plus. What does the TBN braintrust think? He only wants $500 for it, seems fair.
/ Log Hauler
The other option would be a deck over trailer and parbuckling the logs up. Cheapest deck over trailer I have found on Marketplace is $1100.
/ Log Hauler #5
May need some tires...bearings? Also need a way to secure logs to the trailer when on the road.
/ Log Hauler #6
I've thought about parbuckling onto my car hauler. I've also thought about putting an arch on the back of it and using hydraulics and/or winch to do it.
Reality sets in and I no longer need to move many logs because the winters have changed so much here that it doesn't get cold enough to use wood heat most of the winter. Went from 6 cords per season down to maybe 1.5 cords.
/ Log Hauler
Yeah, I like the log arches on the back that uses a winch to lift the log onto the trailer. That would require me to buy a trailer, buy a winch and fabricate it. Also log removal is a bit more awkward. This would require none of that. And be $500 all in. IF IT WORKS!
/ Log Hauler #8
Back over the logs, lift them up, slide support beams under the logs, lower them down on support beams, chain and ratchet strap everything down, be on your way.
Sounds easy on paper. :p
/ Log Hauler #9
Maybe pin the support beams in place for safety. You could use bolts with clip pins for ease of use.
/ Log Hauler
Yep, that is what I am thinking. The arch seems quite sturdy, there are numerous pulleys in the lifting apparatus increasing the lifting power. Seems to me like it would work.
/ Log Hauler #12
Do you know your log weights? Trailer weight rating?
That appears to be a 6 bolt wheel, so somewhere around 5K to 7K.
I'd really prefer using a dually, tandem, or tandem dually.
It appears as if there is a rear cross member on the trailer, but is all of that removable so it can drive over tanks?
Oh, what is the weight rating on the winch? It could well be worth more than the trailer.
Whatever you build, it will have to be SAFE. So, it won't be throwing a couple of wood 4x4's under the logs and heading down the road. Think like 1/4" 6x6 steel, or I-Beams. They could be heavy to safely drag under your trailer and up onto the beams.
I believe Cheese Blocks have been illegal for quite some time, at least around here.
/ Log Hauler
Those are all excellent questions. I am going to look at it after work today.
I think the winch might be manual, that is what the lever is on the side I think.
What are cheese blocks?
/ Log Hauler #15
You could use some rectangular steel tubing for cross members. Make one pivot at the front of the trailer, one on the opposite side pivot to the middle, and one on the back if necessary. Then you only have to disconnect one side and leave them pinned along the frame rails until you get the log raised, then swing them under and across.
But in reality, rectangular steel tubing isn't that heavy. You could weld a guide onto each side of the trailer and just slide them in and out by hand. Maybe weld on a handle for convenience.
/ Log Hauler
that would be perfect, it look sturdy, HWY road or dirt road ?
Highway road. I initially have about 10 15-20" pine logs I need to grab with it. I can stay on 2 lane country roads for about 5 miles to get from there to my property.
/ Log Hauler
Yep, heavy rectangular or heavy c channel is what I was thinking. I posted on a sawmill forum and one guy recommended:unsure: pipe rollers as supports so I could just attatch to a tree and drive out to unload.
/ Log Hauler #19
Research the appropriate weight of the logs and see if the weight rating of the trailer is appropriate. Weight of logs can be approximated by the weight per board foot by species.
/ Log Hauler
There is a log weight calculator online as well.
02GER CHICKET HOUSER 240' (A62131)
02GER CHICKET...
2017 Skyjack SJ16 500lb. Manlift (A61567)
2017 Skyjack SJ16...
2008 New Holland T2420 (A62177)
2008 New Holland...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2010 Massey Ferguson 2625 (A60462)
2010 Massey...
JOHN DEERE 50P EXCAVATOR (A62129)
JOHN DEERE 50P...
