400lbs of Lucas red n tacky?
/ 400lbs of Lucas red n tacky? #41
I like the clear gun barrels and you have an air powered pump on the bulk tube for filling the guns correct?. Could you post a picture of your setup?
As a rule I don't do pictures but it's an ARO air powered grease pump and all I did was install a 45 degree zerk fitting in the head end of each grease gun. I fill them via the zerk fitting. with the ordinary grease hose and female coupler. Takes about a minute to fill each lever gun. I do like the clear barrels a lot. No guessing about how much is in each gun. Got the barrels on Amazon some years ago so I have no idea if they are still offered or not or how much they cost today.
/ 400lbs of Lucas red n tacky? #42
I look at it like this. You’re walking down the aisle at the grocery store/hardware store etc. you think wow that’s a great deal on that, but then you realize you don’t need that thing. It sounds like in your case you need and use a lot of grease. The question is are you going to miss the easy use of cartridges? 10 years from now will you look at the large barrel of grease that is more than half full and ask yourself why did I buy that?
Dad sent me to the hardware to buy a pound of 16 penny nails...
I came back with a 50lb box and some splaining to do.
Just as I grabbed a 1 pound box of nails I overheard the store manager say mark down these 50lb boxes with rips to $1 a box.
I grabbed one and the checkout said no way... manager said yes.
That dollar box lasted decades...
When opportunity knocks open the door…
/ 400lbs of Lucas red n tacky? #43
I'm not sure what happened to all of our nails. But building the house we went through several 50 lb boxes. Slick gold colored ones, plain duplex, and galvanized. A few boxes likely lasted for a few decades after that. They really don't go bad very quickly. It all depends on how much one is building.
Of course now I do a lot more with screws than nails. So, those last few nails might last for quite some time.
/ 400lbs of Lucas red n tacky? #46
Thank you. I found some on Amazon too, but then thought doesn’t the plunger tell me everything I need to know.
Ya but..... Don't you want to look cool...lol
/ 400lbs of Lucas red n tacky? #47
Over fifty years ago, I was delivery boy for a dry cleaner. The grease gun had a zerk in the end of the barrel. When the gun was empty, the sent me to the filling station across the street. Someone there would pump it full with the pneumatic gun used at the grease rack.
/ 400lbs of Lucas red n tacky? #48
I don't think the clear barrel is 'cool' at all but it sure is easier to see how much grease is left inside so I don't run out in the middle of greasing something and... I do use 3 different kinds of grease as well and each kind has a distinctive color so I can look at the clear barrel and see what type it is. My LE grease is red, my wheel bearing high load grease is green and the grease I grease the roller noses on my chainsaws is almost clear and all the lever guns hang next to each other on a rack by the air greaser.
I have to say, I paid a whole lot less than what the one on the Summit website is costing. Think I paid around 15 bucks for each one and that included the bottom cap and plunger too.
/ 400lbs of Lucas red n tacky? #49
I would think that the only grease that would get hard like a rock
would be the grease that contains clay
willy
/ 400lbs of Lucas red n tacky? #50
You've got me thinking about lubes. I don't think I need 50 gallons of grease, but I might be able to swing 5 gallons. Lucas Red and Tacky is probably good for farm and equipment. Apparently OK for wheel bearings too. Probably stiffer than I need for bicycles. But it wouldn't be bad for a single all purpose grease.
I like the concept of a sealed pump that pumps into a grease gun.
Unfortunately for oil, every vehicle seems to want a different type of oil. Even several grades of gear oil.
/ 400lbs of Lucas red n tacky? #51
I use the same oil in everything, Shell Rotella T6 5-40 and have for years. Same with gear oil, Shell GL5 85-140. Don't matter, diesel powered or gas powered. Only exception is hydraulic fluid and then it's Chevron All Weather THC synthetic and I don't buy into the additive hype either. Only thing I add to my oil (not gear oil) is Archoil Nano Borate additive. It's not cheap but the insides of my engines are always free from sludge and clean. Modern oil's tend to 'plate' the interior of engines with a tan colored deposit. I don't have any of that in my engines and I own a few, both diesel and gas.
/ 400lbs of Lucas red n tacky? #52
I was surprised my nephew's car was supposed to use 0W20 oil. I wouldn't put heavy oil into it.
They have great prices on most lawn care related things.
/ 400lbs of Lucas red n tacky? #56
Stens customer service is crap!
I use their belts, I got 2 mower belts at different times that I thought might be counterfeit.
I emailed them from their website, included details and pictures each time. Never heard back from them.
And this is how much I like their belts!
/ 400lbs of Lucas red n tacky? #58
I think I got the last one. Sign up to be a stens dealer to check.
Stens called me and said I had to do a 5k buy in. They asked do I do small engines I said no I'm only wanting to buy oil and grease. She says no problem I asked about the red and tackey she said that Lucas is having a hard time supplying grease something with supply chain. The price you got is everyday dealer price she claimed I get 60% off everything if I sign up and 5k buy in. They said they should get some more grease anytime.
/ 400lbs of Lucas red n tacky? #59
If @Fixastuff is a Stens dealer, perhaps he can drop ship to @TripleS, as well as anybody else that needs to stock up on grease.
I might snag a 5 gallon bucket, if I could get one for a good price. I found one company online that seemed to have good prices for the buckets, until I told it to calculate shipping... 20 screens in to the website.
/ 400lbs of Lucas red n tacky? #60
I really hate grease, grease guns, zerk fittings, all that crap. I do own grease guns and a couple tubes
of grease but despise using it. When I'm gone, the guys that end up with my worn out junk can deal
with it. LOL
OVERLAND VACUUM TANK (A60736)
OVERLAND VACUUM...
2022 CATERPILLAR 310 EXCAVATOR (A62129)
2022 CATERPILLAR...
John Deere 6125R (A60462)
John Deere 6125R...
2020 VOLVO VNL760 6X4 T/ A SLEEPER TRUCK TRACTOR (A59906)
2020 VOLVO VNL760...
2003 John Deere 110 Backhoe (A59213)
2003 John Deere...
2014 Chevrolet Express Van (A55973)
2014 Chevrolet...
