Replace motor on MTD 5hp chipper shredder—shaft?
/ Replace motor on MTD 5hp chipper shredder—shaft? #1
Modrob
Gold Member
Power Trac
MTD 5hp chipper shredder that I want to replace the motor with a new (but about 6 years old in box) Harbor Freight 6.5 hp motor.
Best I can measure, I get 5/8” diameter shaft on the HF, but the original motor has a 7/8” diameter at the end of the tapered shaft. I’m seeing lots of adapters out there, but all are 3/4” to 1”, and a few have a taper to them. Anyone else run into this?
/ Replace motor on MTD 5hp chipper shredder—shaft? #2
Ive got one with a bad motor that was given to me. Have been looking on YouTube and saw where some people have got adapters.
Cant remember the exact videos.
I was thinking about rigging it up to my pto.
No more choking down on a small twig.
/ Replace motor on MTD 5hp chipper shredder—shaft? #3
Shaft size on the HF 6.5 is 3/4" as I just replaced a splitter engine. Your old shaft should be 3/4".
Hmmmm…I held a tape measure under the shaft and tried to line up with both sides of the shaft to come up with the 5/8”…I’ll put a micrometer on it shortly and see what I get for sure…
/ Replace motor on MTD 5hp chipper shredder—shaft? #5
You wouldn't want to use an adapter on a chipper shaft. What you could do is check that model and see if certain ones were built with the impeller that fits and use that. I dunno if that is worth your will on a small chipper. I've run into this before on motorized assist baggers.
/ Replace motor on MTD 5hp chipper shredder—shaft? #6
I put a micrometer on the HF 6.5 earlier today, came up 3/4.
I mistakenly ID’d my motor as a Predator—after a better look I find it’s a “Starter USA Professional” model. (Must have been before Predators) …and another label says it’s a “gosoline” engine! 😜
It’s shaft mics out at .62 mm or 5/8”.
The original MTD final shaft end mics at .87 or 7/8”. 😯
After more consideration I’m going to leave it alone—go back to the original motor. Got a new carb ordered for it and that should get it back up to snuff.
Thanks for the help and interest. 😊
/ Replace motor on MTD 5hp chipper shredder—shaft? #10
Unless the new carb is a chinese clone copy. Then you might want to regasket the original instead. Those Chinese "new" carbs aren't usually very good.
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A60352)
2010 International...
CFG Industrial MX12RX (A60463)
CFG Industrial...
2016 JLG 1932ES ELECTRIC SCISSOR LIFT (A59823)
2016 JLG 1932ES...
SKIDDED PLAIN/WASTE WATER TANK (A60736)
SKIDDED...
SKID MOUNTED CONTAINMENT (A58214)
SKID MOUNTED...
