Replace motor on MTD 5hp chipper shredder—shaft?
/ Replace motor on MTD 5hp chipper shredder—shaft? #1
Modrob
Gold Member
Power Trac
MTD 5hp chipper shredder that I want to replace the motor with a new (but about 6 years old in box) Harbor Freight 6.5 hp motor.
Best I can measure, I get 5/8” diameter shaft on the HF, but the original motor has a 7/8” diameter at the end of the tapered shaft. I’m seeing lots of adapters out there, but all are 3/4” to 1”, and a few have a taper to them. Anyone else run into this?
/ Replace motor on MTD 5hp chipper shredder—shaft? #2
Ive got one with a bad motor that was given to me. Have been looking on YouTube and saw where some people have got adapters.
Cant remember the exact videos.
I was thinking about rigging it up to my pto.
No more choking down on a small twig.
/ Replace motor on MTD 5hp chipper shredder—shaft? #3
Shaft size on the HF 6.5 is 3/4" as I just replaced a splitter engine. Your old shaft should be 3/4".
Hmmmm…I held a tape measure under the shaft and tried to line up with both sides of the shaft to come up with the 5/8”…I’ll put a micrometer on it shortly and see what I get for sure…
/ Replace motor on MTD 5hp chipper shredder—shaft? #5
You wouldn't want to use an adapter on a chipper shaft. What you could do is check that model and see if certain ones were built with the impeller that fits and use that. I dunno if that is worth your will on a small chipper. I've run into this before on motorized assist baggers.
/ Replace motor on MTD 5hp chipper shredder—shaft? #6
I put a micrometer on the HF 6.5 earlier today, came up 3/4.
I mistakenly ID’d my motor as a Predator—after a better look I find it’s a “Starter USA Professional” model. (Must have been before Predators) …and another label says it’s a “gosoline” engine! 😜
It’s shaft mics out at .62 mm or 5/8”.
The original MTD final shaft end mics at .87 or 7/8”. 😯
After more consideration I’m going to leave it alone—go back to the original motor. Got a new carb ordered for it and that should get it back up to snuff.
Thanks for the help and interest. 😊
/ Replace motor on MTD 5hp chipper shredder—shaft? #10
Unless the new carb is a chinese clone copy. Then you might want to regasket the original instead. Those Chinese "new" carbs aren't usually very good.
KUBOTA RTV900 UTV (A62130)
KUBOTA RTV900 UTV...
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
Giyi GY-TB47 Telescopic Forklift Boom (A60463)
Giyi GY-TB47...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
