3016hst Mahindra slow crank
/ 3016hst Mahindra slow crank #1
Beaujo
Mahindra 3016 hst
Have a 3016hst using it the other day getting garden ready was running fine went and put fuel in it and shut off, once done fueling went to start and acted like battery was dead, tested battery and it was on the weaker side so replaced with new, still the same thing maybe crank one or 2 revolutions then just stuck acting, took starter off and found it was on last leg as well, so bought a new starter tried to spin over once normal and then back to barely cranking at all install new cables as well. At a loss can a bad hydraulic pump be my issue acts like the starter is under a major load?
/ 3016hst Mahindra slow crank #2
I’d check battery cables/clamps. I had to replace the positive cable and clamp because of corrosion inside the cable on a similar machine. Also when the battery is out might want to disconnect the ground wire to battery tray/frame connection and clean it up with a wire brush or emery cloth,
/ 3016hst Mahindra slow crank #3
/ 3016hst Mahindra slow crank #4
doneill, he replaced the cables . . .
/ 3016hst Mahindra slow crank #5
Is the pto off
Is Transmission in neutral
Is the clutch pedal button solenoid out of adjustment ?
How about where the cable connects to the starter.
Did the starter come with a new solenoid??
How about an update?
/ 3016hst Mahindra slow crank #6
@Beaujo
My Mahindra 3016 is doing the same thing...have you found a resolution?
/ 3016hst Mahindra slow crank #7
Got to ask, have you taken a voltage reading at the starter while cranking? Voltage drop could be easily ruled out. How about an amp clamp on the cable from battery to starter? I had a slow crank on my 1533 and changed out my battery for a group 30 with threaded studs. It required reworking the cables and a fabricated hold down bracket but even with the starter that went swimming once, it cranks over better than new.
2011 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A60736)
2011 TROXELL...
CAT 336E (A58214)
CAT 336E (A58214)
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
Bell 1600 Gallon Nurse Trailer (A61307)
Bell 1600 Gallon...
2012 DOOSAN G25KW GENERATOR (A60736)
2012 DOOSAN G25KW...
John Deere 5075E (A60462)
John Deere 5075E...
