Pull down a high widow maker.
   / Pull down a high widow maker. #1
JasperFrank
Elite Member
Ford 1220
I've got lots of these now after the latest storm. Do I hire out, or do I toss a lead over the branch to see if i can pull it out? What is the best way to "rope" a high branch?
   / Pull down a high widow maker. #2
I'd have to see it to judge.
That said, do you need to get it down? If she's out in the woods, it will eventually go down on its own. I've got a couple I'm waiting on, but luckily the big poplar by the trail went down on its own.
   / Pull down a high widow maker. #3
How far up and how big is it? What is it hung on?
   / Pull down a high widow maker. #4
   / Pull down a high widow maker. #5
I never screw with any branches up in my trees. If the wind don't blow them out, I call one of my arborist customers with a high ranger and have them remove it. Not called 'widow makers' for no reason. Besides, I'm scared of heights and it costs me nothing. I take that out in trade for sharpening chipper blades and saw chain loops. In fact I have a diesel powered Bandit chipper in the yard right now that needs some work. It's a big one. Mounted on a semi trailer.
   / Pull down a high widow maker. #6
I have nothing but ancient Ponderosa pines. They form a semi-circle around my house and out buildings. Far enough away - when a limb or tree might fall - nobody cares.
So......I certainly do not bother with hanging limbs or tilting trees. If/when it falls - if it will hurt nothing - leave it alone. Let Mother Nature take care of it.
   / Pull down a high widow maker. #7
After cleaning up about 200 large fallen pine trees (and still cleaning them up), I can sympathize with you.
   / Pull down a high widow maker. #8
Use a bow and arrow. Tie a small long rope to the arrow, get it over the branch, and then pull a larger rope as required to attach a larger rope.
   / Pull down a high widow maker. #9
I've got a few from the last storm.
One was 20 feet up. Stable when not windy, and dancing around in the wind.
I was careful to stay back when windy.
It is down now.
I can't throw a roping rope that high and catch anything.
For the ones at ground level. If I cut them off the ground and they don't come down, I'll come back with the tractor and a rope to pull them down.
   / Pull down a high widow maker. #10
Better than cleaning down. :)
I'm on a mission to stop using the word "up" after words. Like heating "up".
   / Pull down a high widow maker. #11
As other posters have stated; we would have to know where these widowmakers are situated. How much land do you have? How far from the your house are these located?
   / Pull down a high widow maker. #12
Need pictures.
I have a shot and line to get a bull rope over when needed.
Do not bother as others have said if it is off trail or in the woods.
Can a bucket truck even get to where these trees are?
   / Pull down a high widow maker. #13
Cleaned plenty down, too.
   / Pull down a high widow maker. #14
That is a technique that tree climbers sometimes use to get their climbing rope up in the crown. Usually over a sturdy limb.
   / Pull down a high widow maker. #16
In the arborist world, that is called a Throw Rope. It's a paracord with a weight on the end that you throw up in a tree or shoot up in a tree and then use that to increase the rope diameter to yank the limb out. They also use it to set their climbing ropes so arborists without hi-ranger equipment that have to physically climb a tree.
   / Pull down a high widow maker. #18
Usually, with the help of a neighbor, we would take down the dead stuff ourselves using several of the ideas already mentioned. I was a telco lineman and would sometimes use my gear to climb when necessary. Too old to fool with it now though.
Around here, dead trees or branches, in the vicinity of a power line, are removed by the local utility company at no charge. There are exceptions though. I had three dead white pines, all over 150' tall, along my private road. The trunks were 36" in diameter at the base. If one were to fall on the adjacent power line, it would surely break off one or more poles and take down the line itself. I called the power company but they refused to remove them. No way was I going to mess with them myself.
Fearing an extended power outage, I called a tree service. There's only one in the area, and they won't touch them either due to the proximity to the pole line.
Over the years, two of the three trees came down on their own and luckily, fell back into the woods, away from the power line. The third is still standing and I'm keeping my fingers crossed.
Lots of them that look like this. They are most all maples that cracked off branchings at the crown. They are in areas we use. I'm thinking a long rope tossed up, tied and tethered to the tractor a good distance away. Then see if I can pull them off and down. This is just one, I have about seven others that look the same. I could just cut all the trees down, but I want to save them. None are near utilities or structures.
   / Pull down a high widow maker. #20
I like to tie my rope through a pully so the tree goes in that direction and not towards tractor or truck.
Strap around a good tree , attach pully.
Make sure branch has a way to go so it does not hang up again or damage another tree.
be careful roping as that might be enough by itself to bring some branches down.
Sterling 9500 (A61306)
2021 BOBCAT S66R SERIES SKID STEER (A60429)
2021 BOBCAT S66R...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
UNUSED DSBREAK DS140A HYD BREAKER W/ BIT (A60432)
UNUSED DSBREAK...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
Traxmax Stand-On Track Loader Skid Steer (A59228)
Traxmax Stand-On...
