John Deere joystick grip part#
/ John Deere joystick grip part# #1
Boss 302
Va.
Kioti RX6010PS Mahindra 3510 Sold (Gonna miss that ole girl)
I'm looking for the part number for the 3rd function grip with wire harness that I can install on my joystick.
/ John Deere joystick grip part# #2
Don't know it as one piece, but the harness is LVA17501, the 3rd funtion grip half is LVU16650, and the other half of the grip is LVU16701. There are tapping screws and bolts to assemble it as well. Switch and handle halves are common across many tractor models.
Thank you J, I appreciate it.
Just finished ordering, again thanks for the info.
Just finished the install on my Kioti RX6010, I must say it's a nice addition.
/ John Deere joystick grip part# #4
That OEM 3rd function on the Ergo handle sure is nice (y)
That's what I've heard, probably will have to do a little adjusting to make it fit my loader stick.
/ John Deere joystick grip part# #6
Both my JD 5115M series has that 3rd function but my older 5101E doesn’t :cry:
It just looks like it belongs there, with everything at your fingertips.
/ John Deere joystick grip part# #8
Thanks for starting this thread because it's on my to do list.
/ John Deere joystick grip part# #9
The third button is a blank from the factory. Bolton Hooks is developing a kit to add functionality to this blank switch. It is a pricey upgrade, but it you have to replace or add the handle switch; it may be an option.
/ John Deere joystick grip part# #10
We do have a few ready to sell, but they ar pricey since the JD switch pod we modify keeps going up in price.
The switches in the handle are only good for 1/10th of an amp, so the use of relays is required.
/ John Deere joystick grip part# #11
Oh,
Here are all that parts that make up the handle, the prices are NOT current though:
That's good info thanks for posting, I didn't see any specifications on the switch.
On mine it wasn't a direct replacement fit, the diameter of my shifter was too small, so I just cut a piece of 1/2" copper pipe for a sleeve, and it worked perfect.
/ John Deere joystick grip part# #15
Kenny - is this grip an easy replacement for the old knob? I have a 2007 3720 with the old knob. Would this grip screw be an easy swap (electronics aside)?
The new grip mounts with two bolts, so you'd have to at a minimum drill those holes. I am not sure if the diameter is the same either.
/ John Deere joystick grip part# #16
Are you putting a harness on a switch that's already built into the pod, or adding your own switch? If adding your own, can you do either NO or NC momentary configuration?
/ John Deere joystick grip part# #17
Are you asking me?
We are adding a switch to the circuit board, it's explained on our website. The switches are NO, I'm not sure if a NC version is available.
/ John Deere joystick grip part# #18
Are you asking me?
Yep, sorry I wasn't clear. I think this might work for my application, perhaps even without the relay box. I'm thinking of using this as an alternate operator presence button, wired in parallel with a (assumed NO) seat safety switch, such that I can hold that button to lift my butt off the seat without the tractor shifting to neutral.
I need to verify the seat switch is indeed a simple NO SPST, and if so, check the maximum current on that circuit during various operations (eg. with w/o PTO), to verify it's always well under 100 mA. If so, do you have a listing/price for just the switch, without the relay box? I'd really like to keep added wiring minimal and clean.
UNUSED ATS GAC40Y 40 GAL.AIR COMPRESSOR (A62131)
UNUSED ATS GAC40Y...
(APPROX.18), 40"X159" INSULATED PANELS (A62131)
(APPROX.18)...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A62131)
UNUSED WOLVERINE...
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A63118)
Case Wheels for...
2018 Chevrolet Tahoe (A61569)
2018 Chevrolet...
