3-Point Hitch 3 point levels tuck
/ 3 point levels tuck #1
JDuser
JD_2024
John Deer 5203 three point hitch control levels stuck in position, however my pull type hydraulic remotes works well,
Any suggestions.
I mean stuck in one position
/ 3 point levels tuck #3
I'm assuming you mean that the 3 point hitch is stuck in the up position? And that it's not the control lever that is stuck..
Have you checked to make sure no one has fiddled with the lowering speed adjustment valve usually located somewhere near the seat? This is typically a turn valve, used to adjust how quickly the 3 point hitch is allowed to go down. If turned completely closed it will not let it lower.
Knoelder Dial-A-Mix Auger Wagon (A66408)
Knoelder...
2012 Peterbilt 367 Sleeper Truck, VIN # 1XPTD40X5CD149943 (A65563)
2012 Peterbilt 367...
New Quick Attach Hay Spear (A65563)
New Quick Attach...
2012 SOUTHERN 130 BBL VACUUM TRAILER (A65643)
2012 SOUTHERN 130...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
John Deere Mower Model LT155 (A62679)
John Deere Mower...
