474HC Will it pull logs?
/ 474HC Will it pull logs? #1
fishbones
Michigan
Kioti LK3054
Yep, still trying to decide. I really like the 494 but its just to big for my barn. I have a lot of grapple and log skidding work to do but cant find much information on how they pull logs so I am hoping someone has some insight.
/ 474HC Will it pull logs? #2
Depends on terrain and the weight of the logs. There are plenty of examples of members using tractors to pull logs within reason in the show me your woods thread, but tractors are not substitutes for bulldozers or timber skidders.
/ 474HC Will it pull logs? #4
A team of horses will pull logs just fine if done right, no reason a 494 can’t if the terrain isn’t to severe and you use your head and they are not giant red wood trees.
What I call a grapple is more for large logging skidders and tractors. Takes up to much weight lifting capacity on a small tractor.
With horse and old drawbar only tractors they made a simple sled pulled with a chain to set the front of the log on.
Smaller tractors work well with a simple arched 3 point drawbar to chain the log to. If pulling greater distances and the train is fairly straight and suitable for wheels a wheeled arch is a nice addition to the back of the log to ease the pull.
Be careful going down hills however as the log of lifted on wheels will want to push you.
Also one dangerous thing some do is just use a bar between the lower arms. Without the top link if it catches a stump it can quick flip over a tractor backwards faster than one can react.
I should have posted the link. Tractors and wood! Show your pics
If you intend to do a lot of work with logs, take a look at the 3pt logging winches.
Thanks, I started going through it last night, thats a long thread :0) I just need to clean up 15 or so downed trees and a bunch of brush. I was thinking of building or buying a 3 point skidder. If this was going to be ongoing I would definately look at a winch.
/ 474HC Will it pull logs? #7
TYM T474​
TYM T474 tractor photo
2019 -
Compact Utility tractor
Weight3230 to 3605 pounds
TYM 474HC
Will it pull logs?
YES
Sufficient tractor weight is more important for most tractor applications than increased tractor horsepower. Bare tractor weight is a tractor specification easily found in sales brochures and web sites, readily comparable across tractor brands and tractor models, new and used.
Within subcompact and compact tractor categories, a significant tractor capability increase requires a bare tractor weight increase of 50%. It takes a 100% increase in bare tractor weight to elicit MY-OH-MY!
TYM T474​
2019 -
TYM 474HC
Will it pull logs?
YES
Thanks Jeff, good info.
/ 474HC Will it pull logs? #10
Too big, how? I got lucky and built the barn to accommodate the tractor, with cab, if needed
/ 474HC Will it pull logs? #13
Unless these downed trees are absolute monsters, I don't think you'll have any issues at all pulling the logs out with a 474 sized chassis.
I think traction will be you're limiting factor here, not tractor chassis size.
I've pulled some pretty hard pulls with my 25 series, 4200 lb bare chassis, 7100 lbs all dressed up for the party. Keep it in 4wd and low range if you're pulling on monsters and worried about it. You can always cut the logs shorter if they're massive.
No where in this thread have you mentioned how big the actual logs will be. That is key information. How big? What species of tree? There are lumber weight charts that will give you a good estimate of how much actual weight you're dealing with.
Logs are 30-40 ft, white oaks, not green, 14-20" diameter. I am figuring I will have to cut them up. I would like the 494 but would have to cut the rop down in order to put a permanent sunshade on top. Thanks for the info.
/ 474HC Will it pull logs? #15
Heck if you cut those in half, I'm thinking your current Kioti could drag those all over heck and back (one at a time, of course).
Certainly wouldn't be a problem with the 474 or similar sized chassis.
I am having a local guy fabricate a 3 point log skidder, I was thinking of having him mount a 2" hitch receiver on the top of it so I can put my 24x48 storage rack on top to store chainsaws and other gear when skidding. I am not sure if it will be in the way or not. Hoping someone who has done skidding could chime in.
/ 474HC Will it pull logs? #20
Barn only has an 8ft door.
This is the reason I went with a T474 vs a T494. The 474 fits in my garage with an 8' door with a few inches to spare. The 494, although my first choice, would not fit.
I pull logs out of the woods all the time.
2012 KENWORTH T800 HYDROVAC (A67714)
2012 KENWORTH T800...
2003 (INOPERABLE) CHEVROLET C7500 (A67714)
2003 (INOPERABLE)...
2014 CHEVROLET CAPRICE POLICE CAR (A66091)
2014 CHEVROLET...
2013 CHEVROLET TAHOE (A66091)
2013 CHEVROLET...
2016 Mobility Ventures Van (A66738)
2016 Mobility...
Sandblast Skid (A68134)
Sandblast Skid...
