Importing and modifying a new mini excavator from China
   / Importing and modifying a new mini excavator from China
He rented his machine out and the customer bent the motor mount.
The way I would approach it is to take a plasma cutter or angle grinder and cut a slot most of the way thru where the bend is. It looks to be 9/16" plate like mine.
Then, I would use a ratcheting chain-binder or beefy come-along and pull against the other frame tail. When straight, I would remove the motor and weld the kerf.
That part of the frame after bending is weaker now, so must be strengthened by welding to avoid another bend in the same location. I would also put a brace between the frame tails. You can't just bend it back without strengthening.
If that person posts any pix of the fix, then I would love to include them in a repairs thread I want to start.
   / Importing and modifying a new mini excavator from China #1,202
Interesting link. Thanks for posting. Different names for some of the same kinds of valves
Of even more concern should be the wheel motors. You should look into adding cross-port RVs (counter-balance valves, or wheel braking valves) to the wheel motors. This was done by request to the maker by local importer Jason. It helps a lot with keeping the mini-X from going downhill too fast. A Big Problem.
Note that ports already exist on the motors, but there is no info on how they are connected. Have you looked into this? Photo shows a wheel motor with attached valve block with 2 RVs.
It appears to be a flange-type counterbalance valve which have O-rings for sealing.
BM5 Series Orbit Hydraulic Motor Counter Balance Valve
Unfortunately, my drive motor doesn't have threaded holes, so installation would be difficult, and it seems like modification is necessary.
Freewheel of the motor can be dangerous, and it can also cause system damage due to cavitation. Depending on the operating environment, it may be necessary to install it.
   / Importing and modifying a new mini excavator from China #1,203
Hey guys. It seems like we just talked about this. The pics are from a Facebook group user. He rented his machine out and the customer bent the motor mount. I feel bad for him and he mostly got criticism instead of help. I figured I would ask you smart guys about any possible straightening solutions. I believe the machine is still in the field. It is a 1.8 ton AGT 18.
. . . . Yep. And if you look closely at my pics and fix (that initiated the discussion) you'd already have your answer (to share with your facebook friend.)
That's the exact same geometry/frame as mine and a 4t chain binder pulled mine right back in. (both at once in my case.)
ALSO just my 2 cents - this thread and it's users are unique (at least to a degree) from the 10k's of FB people and I think that's a good thing.
I don't think it's a great idea to bring alot of FB content here especially random posts.
I know for a fact proper searching on FB would have returned similar posts and solutions to what has also already been posted here.
   / Importing and modifying a new mini excavator from China #1,204
You may not be as unique as you think, there are plenty of snobs there too. This is a unique situation that requires some unigue problem solving. He is a inexperienced young man who doesn't have access to many tools in the field. I contacted him to see if we could come up with some suggestions. He's not "random" or inconsequential. We are here to help and some other comments have been very helpful. Sorry if I read too much into your comment but he has mostly gotten criticism on Facebook.
   / Importing and modifying a new mini excavator from China #1,205
Whoa hey no offense haha
Searching this thread for 'frame bent' only returns a few results with mine towards the earliest. post 1094. pics reveal same frame type/geometry and bend type. details of post reveal the fix.
As Dave mentioned yep reinforcement is prob almost a requirement after.
FB . . . . my opinion is not about 'snobs' - it's that FB is kinda a sh!tshow IMO compared to here- besides the rampant advertisers/sellers they have many very very green users ( that are potentially too dum or too lazy to search for answers) that are repetitively asking the dumbest questions over and over or just generally making low value posts/replies. Again, JMHO i personally wouldn't look forward to bringing that here.
And as also mentioned the FB groups (that I belong to) are searchable to find the posts where I initially confirmed my frame problem and include varying fixes to mine. From what I've seen mine was combo of the simplest method yielding best result.
Dude that is smart enough to be buying and coordinating the renting out of equipment should also be smart enough to do some searching or at least hire someone to maintain/repair his stuff if he can't . . . . Again this is just my 2cent.
I agree that a counterbalance valve (crossover RV with anti-cavitation check valves) is superior to a crossover RV alone. I asked HeChuang (thru our local importer who speaks Mandarin) to see if I could retrofit my wheel motors with the wheel-braking valve in my above photo. (Answer: no)
What about locating 2 crossover RVs or counterbalance valves inside the house to protect the wheel motors? Not ideal location on the motors, but there is room inside, and adapting to wheel motor near the valve is not hard.
   / Importing and modifying a new mini excavator from China #1,207
I passed on yours and oldrustysteels suggestions. I knew yuo guys would have some unique approaches. Whether he puts them to use or not remains to be seen.
   / Importing and modifying a new mini excavator from China #1,208
I was just giving you hell man, no offense taken or intended. If we can't joke then life is boring. I guess I agree with you about FB being all over the place but there are a lot of inexperienced people who just want to learn. I know I have had to ask dumb questions before therefore I don't mind answering the same questions over and over again. Plus, I don't think most FB users would like this forum. Instant gratification and easy targets don't abound here.
Hearing about bending the frame is a really new thing for me. I am on the lookout for unexpected failures that can be possibly avoided. I thought more would show up with higher hours, but that seems not to be the case.
I have only had to fix a few failures so far, and that's good. My machine is back up on the trails working, but I would like to bring it down to the workshop to add a crossover RV (on order) to the house motor.
As for groups to discuss technical things, I will have to get access to FB groups eventually. I used Yahoo groups years ago (now dead), and Usenet groups before that. TBN still has pix I posted more than 20y ago. Utube still has my earliest vids, from 14y ago. Note that you do not need to be a member, usually, to lurk TBN and other sites. Not true for FB, sadly.
   / Importing and modifying a new mini excavator from China #1,210
Hello All. I'm new to the group. I just finished reading the comments from start to finish and wished I had done so before picking up my AGT L12 at auction about a week ago. I paid $4225 plus auction fees and sales tax for a total of about $4925 out the door. There were 22 AGT units up for auction, only 2 L12's, a couple of H15's, and the rest split between H12's and QH12's. All of the units went for low $4000's except for the H15's which were low $5000's.
I liked the L12 because of its openable "hood" and that it comes with a hydraulic cooler. Sadly, no spin on hydraulic filter, which I plan on remedying asap. The lcd hour meter was full of water and no functional, since replaced with an electric/mechanical style. The digging force is very weak, I hope due to the relief valve being set too low. I cranked it up a bit and it seemed to help, but don't want to push it until I can get the adapter to get a gauge on it. I've already been ejected from the drivers seat, picking up a pretty good hunk of freshly cut firewood and pivoting sideways. She's a tippy one.
2023 JOHN DEERE 325G SKID STEER (A52709)
2023 JOHN DEERE...
2021 Chevrolet Silverado 1500 Trail Boss 4x4 Crew Cab Pickup Truck (A56858)
2021 Chevrolet...
2005 UD Truck UD1300 Landscape Dump Truck (A56858)
2005 UD Truck...
Electric Golf Cart (A56859)
Electric Golf Cart...
CFG Industry MX12RX Mini Excavator (A57149)
CFG Industry...
2014 Case SR210 Rubber Tire Skid Steer, S/N NEM481428, PIN# JAFSR210AEM481428, Turbo Diesel Engine, (A59076)
2014 Case SR210...
