Generators stand still, Porsche's move. Still not an insurmountable problem, but it does require some long time constant to mind the sloshing. Our 2005'ish Audi A3 had a low oil level sensor, which would trigger a light on the dash, so it's been done.Porsche tried (static) remote oil level detection a while back.... last I heard, that wasn't working out so well, but I'm not a Porsche guy, so may be out of date. Our stuff would be shutting down on low-pressure.... I've banged on before about why a $400 generator has this from the factory, but a $100k vehicle does not... could be better detection on gens, but at least they have something !![]()
I have one on the hydraulic oil reservoir of my log splitter.I know my neighbour has a temperature sensor dipstick on his Harley. Analog needle, and survives Vtwin vibes, but don't know what thread that is.....
I defer to ThoreauGenerators stand still, Porsche's move. Still not an insurmountable problem, but it does require some long time constant to mind the sloshing. Our 2005'ish Audi A3 had a low oil level sensor, which would trigger a light on the dash, so it's been done.
thanks, I'm impressed by this.
My B&S whole house generator has low oil pressure and high oil temperature sensors. High temperature sensor did its job last year when muffler broke and overheated engine compartment. Generator is 18 years old. First repair needed except battery and normal maintenance.thanks, I'm impressed by this.
My Westinghouse sure doesn't have that.
I wonder if a conventional Briggs Vanguard say 30hp has a high oil temp sensor.
now the real question is how often have you seen these sensors do their job, or not?
if an engine blows, was it always due to low oil?
I'm curious how the low oil sensor works when it is positioned well above the oil fill line.
no oil pump, ?
There's an old saying about cars, no longer true, but was for generations:I defer to Thoreau. Even resurrected, I doubt he'd be P's target market today.....
It's a German Thing..... reminds me of Leno, going on about the complexity of what Mercedes finally deigned to put into their cars, for a cupholder....
Rgds, D.
Good point.My B&S whole house generator has low oil pressure and high oil temperature sensors. High temperature sensor did its job last year when muffler broke and overheated engine compartment. Generator is 18 years old. First repair needed except battery and normal maintenance.
"The British over-design, the Japanese under-design, and the Germans just get it right."
As you noted, the Germans and the Japanese have probably swapped in that regard in recent decades, although I still find their cars more fun and sexy on average.
Haven't played with the guts of small engines enough to be certain, but w/o an oil pump, I'm suspecting that crank-splash may be creating some low pressure baseline @ normal oil level.thanks, I'm impressed by this.
no oil pump, ?
