Pump out Fuel Oil Tank
/ Pump out Fuel Oil Tank #1
hube2
Paris, NY
Masey Ferguson GC1725M
I need to pump fuel oil out of my tank in the basement.
I have a pump that will do it, the issue is that I cannot get the hose for the pump to snake down into the tank from the fill pipe outside. The hose must go around a couple of 90 degree bends and the hose is getting caught on where the pipes thread into the elbows.
The hose is a 5/16 inch ID hose (1/2 inch OD).
Does anyone know of a fitting I can put on the end of this hose to allow it to get past where it's getting stuck?
And also not restrict flow so that the pump will still work?
I'm imagining some type of a round ball with a fitting that pushes into hose in the same manner that the hose connects to the pump.
I've tried searching and all I can find is a fitting that goes on a pressure washer and this would not work because it would restrict the flow into the hose.
My other option is to take the bung out of the tank in the basement and pump it from there. I would rather avoid doing this and it would be my last resort.
/ Pump out Fuel Oil Tank #2
I would do it from the basement. With a pump at the fuel tank, you are much better positioned to move the fuel a long distance.
Any hose that is flexible enough to make it around a 2" 90 degree bend is likely to collapse under the suction of pumping the oil up and out.
Can I ask why you want to do this? I've only had to do this once, but fuel oil company came and did it for us. (And paid for the oil, IIRC...)
All the best,
Peter
I have a pump with a hose that is designed to do this. The hose is fairly stiff but it does go around the corners. I can get it past the first bend but it hangs up on the second.
/ Pump out Fuel Oil Tank #4
How many gallons do you need to move? I helped my brother out with a similar project but the tank was less than 1/3 full. We filled 5 gallon jugs straight off the tank's filter line, and lugged them up the stairs and out of the house to a truck with a couple of 55 gallon drums in the back. By the time I lugged my 10 gallons and returned to the basement his jugs were full. Took less than an hour. We screwed around with a pump for most of an hour before we gave up and went the manual labor route.
/ Pump out Fuel Oil Tank #5
I assume this goes to Oil furnnace or boiler. It must have a shut off where the bung is you referred to. Can’t you simply unhook the line at the appliance and let it drain into 5 gallon cans to take where you need one at the time.? It’s a little slow but not really much slower than any flexible tube you’re going to get down past that double 90 and to bottom of the tank. Then again, you don’t need to have any sort of pump to do the job either.
  • Good Post
Reactions: JJT
/ Pump out Fuel Oil Tank #6
Kind of a dumb question but could you do something like what we used to do pulling wire in conduit like building up the end of the hose with something like black tape or attach a piece of fish tape to the end of the hose that will go ahead of the hose and allow you to get it through the elbow? Forgive me if I have mis-understood what the problem is.
/ Pump out Fuel Oil Tank #7
Are you going to be removing the tank after it is empty?
If so maybe remove a couple pieces of the fill piping.
Also, I am assuming you are trying to use the fill pipe and not the vent pipe as most likely your vent piping has a whistle at the tank which would not let a line through. Or connect your suction hose to the feed line.
To answer some questions.
It's a long story.
I have 550 gallons of fuel oil in 2 tanks. This is for my baseboard heating boiler. I now have heat pumps recently installed and will never use 550 gallons. I had the tanks filled before I decided to have the heat pump installed. Based on my oil usage this year it will take me 15 years to use the fuel. The fuel will go bad long before then.
I was toying with the idea of getting the pumps, but was not really planning on it for last year. The price was right so I got it done. If I had planned for the pumps I would not have had the tanks filled last spring.
I still need the boiler as backup to the heat pumps for the really cold days. So I will not be removing the boiler or the tanks.
I am trying to get the oil out of the older of the 2 tanks. My plan is to use it in my tractor. The fuel oil in my tank is diesel, no different than what you buy at the pump except that it is dyed red.
At this point I just want to burn it up or use it, give it away if I have to. I just don't want it to go to waste.
At this point I have turned off my heat pump and plan to just run the boiler for the rest of this year to burn up as much as I can. I have also turned off the newer of the 2 tanks so I can burn up what is in the older tank first. I doubt I will ever go to the expense of having one of the tanks removed. I'm too old to care or worry about an empty tank sitting in my basement.
My actual, initial plan, what to put diesel stabilizer and biocide into the tanks and then pump the diesel out and back in to get it mixed in.
Once this is done I was going to pump it out into 5 gallon cans for my tractor. My FIL also make maple syrup and uses a fuel oil (diesel) fired evaporator. He buys off road diesel 40 gallons at a time for this and I was planning on giving it to him as well.
At this point the fuel is already paid for. I could just burn it up to heat my house, but somehow I feel that is a waste if I can put it to better use.
/ Pump out Fuel Oil Tank #9
I pumped out a basement fuel oil tank years ago using a standard diesel transfer pump and 100' of garden hose on the discharge side to 55g drums outside. I used an existing cap on the tank, measured and cut a section of PVC suction pipe for the pump intake.
It didn't take very long, and I had several years (at the time) of free diesel.
/ Pump out Fuel Oil Tank #10
Sometimes it’s a matter of rotating/twisting the hose so that, eventual,y the end also rotates to the “right” orientation when it meets a bend.
Easier said than done and circumstances very greatly.
I think I found what I was looking for, or at least something that might work, especially if I take a file to the sharp edges. Story to be continued.
The problem is that the hose is stiff enough to not kink/collapse going around the elbow. I stood out there today for an hour twisting and turning the hose trying to get past the 2nd elbow with no luck.
/ Pump out Fuel Oil Tank #13
I have removed a few tanks. You really need to either hook up to the small tank outlet or remove a bung at the top of the tank.
I also use HHO in my diesel machines. I filled up the 275gal house and a 275gal external tank at $1.28gal in early 2020. I suspect it will take me another 5+yrs to use this much oil
/ Pump out Fuel Oil Tank #14
Is there a reason you're trying to run the pump outside? There should be a valve at the base of the tank where the line goes to the furnace. Turn that valve off, remove the line and connect the hose from your pump. Should take just a couple pipe and/or barbed fittings. Turn valve back on and pump away. No reason to try to feed a hose down through the supply line.
Because I don't want the stink of fuel oil in my basement. I'm also not removing the tanks. I just want to use up the excess before it can go bad. I want to keep the tank hooked up to the furnace.
/ Pump out Fuel Oil Tank #16
Doing what I suggested has nothing to do with removing the tank. It's also quite easy to simply hook the furnace back up when you're done. There is a possibility of a small amount of fuel spillage, though with a few precautions that can be easily mitigated. If that's just not of interest, be sure to check the lift rating of your pump before going to too much effort. Many small pumps like that can only lift a few feet.
/ Pump out Fuel Oil Tank #17
I think that @BlueKnife makes an important point.
@hube2 when you check the lift rating make sure that the lift rating is for diesel. Lift ratings for oil and water are very different (larger) than the lift for diesel which will be much less due to the fuel degassing and vaporizing.
All the best,
Peter
The pump I have says it has a 10' lift rating for diesel.
But to be honest, I don't know exactly what the means.
Is it 10 vertical feet?
Or is it 10' of hose even if the hose runs mostly horizontal for say 10 or 12 feet but the total vertical lift is 10' or less?
I have 2 tanks.
One is less than 10' from the top of the fill pipe to the bottom of the tanks.
The second tank has the same vertical distance from pipe to tank bottom, but it has a significant horizontal pipe get to the tank.
I'm not concerned about the 1st tank, but I have a question about the second tank.
This is what I was trying to check/test when I started this thread. I was trying to get the hose into the furthest tank to see if the pump would actual pull the fuel out of it.
I'm still waiting on the ball hose end that I ordered. It's on back-order. This is okay because the cold has returned. The day I was testing it was nearly 50F outside. But when I get it I plan to see if it will let me get the hose into the furthest tank and test it.
/ Pump out Fuel Oil Tank #19
I have 2 tanks.
The lift rating is the total vertical height of the pump above the top of the liquid it's pumping. Pumps can push a lot further than they can pull.
/ Pump out Fuel Oil Tank #20
@hube2 The lift rating is for a straight vertical lift. Horizontal distance adds to the friction in the pipe and will decrease the lift somewhat.
All the best,
Peter
