Jd970-jerky sterring
/ Jd970-jerky sterring #1
Jdeere970
Jd 970 1996
My steering is jerky a raising my blade is slow.Changed my hydraulic filter on oil didn’t help much.It’s a jd970/1996 with about 900 hrs
/ Jd970-jerky sterring #2
Did you clean the screen also when you replaced the hyd filter?
/ Jd970-jerky sterring #3
What Peter said, be sure to clean!!
Also what was the condition of hydraulic fluid when you drained it? Golden/honey color.. Dark.. Milky..??
It was dark.
/ Jd970-jerky sterring #6
/ Jd970-jerky sterring #7
Sorry.. Forgot to mention the screen is in the transmission housing and is Part #5 in the schematics of the link above.
Thanks for the information
/ Jd970-jerky sterring #9
JDeere970, those are nice tractors. 900 hrs is nothing. But time to clean that screen.Here are the two pages from the JD970 operators manual that talk about changing the trans/hydraulic fluid. The location to remove the tubular cleanable screen is shown.
First you have to drain the trans/hydraulic fluid. It needs to be super clean. That fluid is expensive. Roughly $150 for 6 gallons at Amazon or the tractor shop. Use JD's Lo Viscosity Hy Gard for smoothest performance. Also helps the tranny. Cheapo "tractor fluid" is usually too thick for wintertime in that tractor. Sometimes the Hy Gard container just says "Winter" instead of Lo Viscosity.
If your fluid is recent, you can reuse if it is clean and still transparent. If milky, disgard it and flush with cheap oil. Milky-looking trans/hydraulic fluid means it is holding water in suspension. Best way I know to clean fluid if it is NOT milky is let it set for a few days in a clean container and then carefully pour it off or siphon it out to leave the crud behind. Expect to lose some. Sounds like you won't have to do the main filter again unless it is some aftermarket type and you want to play it conservative.
The cleanable screen is under the cover in the picture. It is a tubular mesh screen. The screws are metric allens I think. You can clean the screen with a tooth brush. Some screens were metal and others nylon mesh. Clean the crud off the outside and slide it put it back together.
There is no gasket there, just an O ring. Lots of places have the CH17154 O ring. Amazon, Walmart, JD..
I think Walmart and Amazon also have the Hy Gard Lo Viscosity Fluid.
Good luck,
rScotty
40' Used Container, High Cube, Single End Doors  (A62679)
40' Used...
2016 WEILER P385A ASPHALT PAVER (A62129)
2016 WEILER P385A...
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
2015 Ford Explorer SUV (A61574)
2015 Ford Explorer...
10' Dozer Blade (A64119)
10' Dozer Blade...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
