lilranch2001
Super Member
- Joined
- Nov 25, 2009
- Messages
- 9,122
- Tractor
- Bobcat CT 235
I took one a little bit ago as well!
I'd love to. I've made it a point to not comment on his posts over the past year or so, yet he keeps commenting on me. Not my posts, me. So there you go. If he stopped commenting about me, you'd never hear a peep out of me about him.I’m starting to get the feeling that there’s a personal conflict between ole Moss and two bit……..
Come on guys get along. Have a good time!
To get back on topic, the chairs are not a problem. You want to maintain coverage on the rebar because if it corrodes it will expand and potential accelerate cracking. The wire is so small that even if it rusts, it won't expand enough to cause a problem. As an interesting trivia point, the chemistry in concrete "passivates" the steel so it won't rust, even if there is moisture in the concrete. Rust only happens if the steel is exposed to air.Is there any evidence for the wire chairs, which are sitting either on dirt or visqueen, rusting out and lowing moisture to get to the rwbar and corrode them? The plastic chairs, typically used for wire wouldn't so that.
The reason I ask, is rebar should be, correct be if wrong, no less than 2.5x the diameter of the bar, from the closest edge of concrete. That wire rebar chair, the feet are touching the subgrade surface.
It always concerned me that all the wire I saw going under the concrete was significantly rusty. Maybe it was just surface rust but it looked like more than that to me. I also saw a lot of wire in broken up concrete that had been pulled up which looked like it must have continued to rust after it was in the 'crete. So what you are saying sounds true because oxygen is needed for rust to continue but it goes against what I think I saw. I can accept the premise that the rust won't expand enough to accelerate cracking but if the rust could continue enough to corrode the wire that much it would also not have any ability to hold the concrete together and would become worthless at doing the job it was put there to do.To get back on topic, the chairs are not a problem. You want to maintain coverage on the rebar because if it corrodes it will expand and potential accelerate cracking. The wire is so small that even if it rusts, it won't expand enough to cause a problem. As an interesting trivia point, the chemistry in concrete "passivates" the steel so it won't rust, even if there is moisture in the concrete. Rust only happens if the steel is exposed to air.
Both plastic chairs and concrete chairs ("dobies"?) are superior to plain wire supports, for corrosion and water leakage reasons. I believe that you can obtain epoxy coated wire versions, e.g. Meadow Burke, but I haven't used them or seen them used.Is there any evidence for the wire chairs, which are sitting either on dirt or visqueen, rusting out and lowing moisture to get to the rwbar and corrode them? The plastic chairs, typically used for wire wouldn't so that.
Maybe in areas where they brine/salt roads? It isn't here.And why is roadbed steel epoxied?
I used high density 1.5- 2" foam very minimal distortion, with wwf over it graded and compacted extensively before placing sheets even taped all joints. first time I used foam forgot to adjust for foam thickness lol needles to say I had a large pile of sand afterwords cuz of my f-up and should be in stupid thread. Btw I've had great results using compacted sand using a bit of water to help. I'll say I burn wood at my cabin the stoves on slab once that slab heats up it maintains heat for awhile. if I burn continuously for several days over 90% of the slab can be comfortably walked on barefoot and it's below zero outside.Does the foam retain its shape/structure/insulating properties with that much weight on top of it? I've seen it used only in videos from eastern Europe, and typically with those radian heat floor tubes.
What distance between chairs would accomplish that?My motto is use enough chairs that walking around on the rebar doesn't bend the rebar, or shift it.
I think that depends on the size of rebar in use and the spacing of the grid, doesn't it? Small diameter (number) rebar needs more supports, and larger rebar needs less. I believe that there are tables, like this one; https://www.lotel.com/sites/default/files/user/Rebar-ups spacing chart B.jpgWhat distance between chairs would accomplish that?
You might try searching for "wire dobie" or just "rebar support", or "rebar concrete block".My last large pour, (40 yards, 15+ years ago), I used chairs made from concrete with a built in wire tie. Very handy. I searched and cannot find them now. It seems like plastic or wire are the only choices. I used #4 rebar, 24" on center in a grid format. I have no cracks, I did not use fiber in the small aggregate 4000 psi concrete.
