1st time buyer - 35 hp comparisons
/ 1st time buyer - 35 hp comparisons #81
I think once you are into the EPA engine management stuff you might as well go bigger than 35hp for the intended uses. You can now get 48-50 pto hp in a 6' wide tractor which can run bigger implements and still not require building wide trails in the woods to get around. I like my tractor's size and if I was running a tiller or baler I would want more hp.
/ 1st time buyer - 35 hp comparisons #82
Me too, recommending a bigger tractor. 35 hp is kinda in between the small and big tractors for moderate size property. My 6ft 50 hp tractor runs a 7ft offset flail mower which makes the job easier and quicker.
However first time operators may be more comfortable with the price and feel of a smaller tractor.
/ 1st time buyer - 35 hp comparisons #83
keep in mind a sub compact the size you are considering is not much bigger than a lawn/garden tractor. agree w/others, go larger w/that kind of acreage. you wont regret
/ 1st time buyer - 35 hp comparisons #84
The problem for any first time buyer is having enough personal experience to be comfortable making an initial purchase decision especially when tractor prices today are so high that it would be expensive to buy something that turned out to be unsatisfactory to you.
I think I've said this before, but there's a huge difference in stability and power between my 25hp L2501 and my 52hp MX5200, but I don't know how you'd personally experience the difference other than operating one and then the other for comparison.
I had a 35hp Mahindra 3525 which is a pretty heavy tractor, but the MX is way more stable and has more useable traction and power, IMO. The only thing I don't like is the DPF system, but you're stuck with DPF once you go above 25hp in the USA.
/ 1st time buyer - 35 hp comparisons #85
If you are able, driving each tractor on the lot would be worth your time. Each tractor will feel different and some issue you never thought of may show up. For me, I owned a 30hp Kubota for 15 years when I upgraded. I don't like the single treadle peddle on the Kubota. I very much like the 2 pedals that the Kioti has. That was the one issue that pushed me into the Kioti.
/ 1st time buyer - 35 hp comparisons #86
I’ve seen some pretty poor reviews on the Bobcat version of the Kioti, and some selling really cheap used…. If it’s a Kioti, just buy the Kioti.
Are they different than their comparable Kioti model? I have no clue but have seen them around and at the Bobcat dealership.
/ 1st time buyer - 35 hp comparisons #87
in general i find test driving a tractor at a dealership lot is a poor way to simulate field use. In addition, i agree w/above posters that the MX series would be ideal for an estate tractor. & don't fall into the buying frenzy till you're certain which machine best suits your needs...
/ 1st time buyer - 35 hp comparisons #88
In the several tractors I have owned, I had pre-conceived notions of what the biggest thing I would ever do with it. First tractor I ever owned: JD 790. Made by Yanmar in Japan. Absolutely great tractor. I moved so much brush, trees, rocks and things. Ran a 5 foot bush hog on it. Ran a 7 foot finish mower on it. Had the 70 FEL on it. Box blades, landscape rakes, tillers. What I finally discovered, after a few months, was as great of a tractor it was, it wasn't big enough to do all the chores I needed done on my farm. Especially in a timely manner. I kept it for almost 10 years. Sold it and the implements I bought for it for almost as much as I paid new for it 10 years earlier. I upgraded to a JD 5055D. Great, more weight, more horse power, bigger loader, can power much larger implements. Great tractor. NO Tier Final 4 emissions. Now that my farm is pretty much whipped into shape, I am finding I am not using it half as much as I used to. 14 years later, I am starting to eye a full cab track loader. It has more horse power, can get into tighter areas than my 5055D could ever imagine getting into. It will float on mud. It can dig. It has all programmable, joy stick controls. It has heat and air. It has an unlimited amount of implements you can attach to and run on hydraulics. Forestry heads, brush cutters, forks, grapples, trenchers.....the list goes on and on. Now, my eyes have gotten bigger than my wallet.
I guess what I am trying to say is: Whatever you end up buying, you will find it limitations within a few short months and then you will be looking at something a little bigger. And, that's OK. That is why there is a really good used market on CUT.
/ 1st time buyer - 35 hp comparisons #89
I did over buy once... and I STUBBORNLY KEPT THAT TRACTOR FOR 14 YRS lol.
So glad I downsized to the Kubota MX5200. Yes the DPF cycle is a pain but if working it goes unnoticed.
And the treadle pedal was a concern but 1 yr later I figured out how to live with it. It has pros and cons.
But if you are novice then you have no operator habits to break and soon you will get used to whatever controls you have.
/ 1st time buyer - 35 hp comparisons #90
The tractors are the same, the attachments have a different supplier though. Or that's my understanding.
I think it's more just to get a feel for the ergonomics.
/ 1st time buyer - 35 hp comparisons #91
I’ve read that Bobcat had some design changes, the units were not identical. Again, not unlike Rural King and TYM, where Rural King does not use the Kukje diesel.
As of now, I’m leaning VERY heavily towards the YM342 over the YT235. The 342 is about $1k cheaper and already has the suspension seat, 1 rear remote, and extendable lower link arms, not to mention the 342 is about 1,000 lbs heavier and the loader can lift nearly double that of the YT235. For an “economy” tractor, seems like it has a good bit of bells and whistles.
My main concern is that the 342 has a shuttle shift. I’ve only driven a HST tractor in the past (only twice so still not much experience). If I’m doing 50/50 loader and 3 pt work, will the synchronized shuttle shift be a disadvantage?? I plan to go drive both but can’t get out there during tax season.
I will say that I do know how to drive manual vehicles and I actually like to do so. Just don’t know how precise I can get with the shuttle shift trying to unload something out the back of a truck or trailer.
/ 1st time buyer - 35 hp comparisons #93
I have both Kioti and Bobcat nearby- good to know.
/ 1st time buyer - 35 hp comparisons #94
Shuttle shift rpm is tied to ground speed. HST rpm is set and ground speed is variable. Big difference. HST is more user friendly in all applications. IMHO
/ 1st time buyer - 35 hp comparisons #95
I've had both hydro and shuttle tractors. Prefer Hydro for loader work, prefer shuttle for mowing, ground engaged, 3pt work.
/ 1st time buyer - 35 hp comparisons #96
I'm comparing those two as well, with some dealer input tomorrow. Both great tractors looks like. I want to have some hands on with both of those transmissions, but also am interested in what the dealer has to say about models.
Let me know how it goes. To me, with the 342 being around $1k cheaper and being a whole lot more tractor for the money, I’d like to know if you’d think that transmissions is a dealbreaker.
I also just saw a new 2022 342 model on sale for $25,800 so that’s pretty tempting too
/ 1st time buyer - 35 hp comparisons #98
FWIW, I had a 34hp New Holland hydro. Now I own a 40hp New Holland shuttle. I like the larger frame shuttle way more for the work it gets done. YMMV
/ 1st time buyer - 35 hp comparisons #99
If you have that kind of money to spend and have a good dealer nearby, Yanmar is the real gold standard. Kubota has more dealers, but if all else was equal in this size range, I'd buy the Yanmar with the proprietary transmission.
That’s what I like to hear!
That being said, majority of my work would just be around the house and in the woods. I don’t think I may ever really be using it for field work or at least not in the next 5 years. Still would pick the shuttle?
2016 American Eagle S/A Self Loading Reel Trailer (A60352)
2016 American...
2023 MERCEDES BENZ SPRINTER 3500 4X2 CARGO VAN (A59906)
2023 MERCEDES BENZ...
2025 80in. Hydraulic Dual Cylinder Root Grapple Skid Steer Attachment (A61567)
2025 80in...
2016 Peterbilt 337 S/A Flammable Liquid Transport Truck (A60352)
2016 Peterbilt 337...
66'' Skid steer bucket (A61567)
66'' Skid steer...
2006 FREIGHTLINER M2 106 4X2 24FT BOX TRUCK (A59906)
2006 FREIGHTLINER...
