Fuel additives
/ Fuel additives #1
Mtsoxfan
Newark Vermont
Kioti 3520SEH Holland TC29D
I've never had any gelling issues with my scut, although last year I used a cetone? booster which was billed as keeping injectors clean. I will be using my loader to clear driveway this year, as muscling around a heavy snow blower has been rough on my back.
If it gets really cold, like below 0, I will plug in block heater for a couple hours before. My question is this, are additives necessary? I buy off road diesel from a busy gas station with high turnover. If so, what do you recommend? I keep a bottle of red 911 on hand.
/ Fuel additives #2
I used diesel kleen for the past 15 years, centane booster and anti-gel, but apparently there's a new one that is better, it's in the shop, I'll check when I go out. It's expensive though. I get off road diesel delivered and have never had an issue.
/ Fuel additives #4
I’ve used Power Service, Howes and have a bottle of Lucas now. I’ve had my tractor gel up three times using an additive so I’ve been adding kerosene now. In theory they should be adding kerosene to the pump fuel but the stations never have any idea what they are selling. I’m probably running around 20% kerosene now plus the Lucas additive. When my tractor gelled in the past it was always very cold for an extended time and I keep my tractor inside but it’s not heated.
/ Fuel additives
Most times I get my OR diesel, there is someone there, so that leads me to believe it is high volume.
And I buy 5 gals often, every 2 weeks, in non winter months. Around here, everyone has a tractor.
/ Fuel additives #6
I also purchase OR from high volume station and treat with anti gel kinda like added insurance.
/ Fuel additives #7
Real easy...get a small bottle or jar and put a fuel sample in it. Throw it in the freezer or outside, whichever is colder, and see if it stays clear after a day. I always treat my fuel and use #1 blend if needed. Stations here are mixing at 20% now and contractors are asking for 30%.
/ Fuel additives #8
I don't risk fuel issues, and use PS White in the winter months. I also ensure I use up my summer blended fuel around November, and get (supposedly) winter blended fuel.
Don't count on the supplier. While high volume is a good sign, is not a guarantee of good fuel. I used the same high(ish) volume supplier for several years. I started having contamination problems clogging my filters, only to discover almost an inch of dirt, sand and small gravel in the bottom of my transfer tank that the intake tube was picking up.
You do not want to deal with gelled fuel.
/ Fuel additives #10
When I got my first diesel tractor a few years ago it had been sitting, according to the seller, for 2 years without being started. Per advice here I bought some Power Service Diesel Kleen additive and started using it. Right away the engine smoked less and started faster. After about a year of use I stopped using the stuff and noticed no difference in smoke. I was told my injectors were probably dirty when I first got the tractor which is the reason for the smoke and the Diesel Kleen cleaned them. I then started using the stuff again after about 9 months just to see what would happen and even though the tractor didn't smoke any less it did start a little faster. The tractor, a 43 year old Yanmar YM2310, doesn't smoke a lot but it did when I first got it. Since the additive is so cheap to use and doesn't cause any harm I continue to use it. Though The only benefit I see is that it cleared up smoke right away and seems to make the tractor start faster. The tractor does not have a working Thermostart but still starts easily when the outside temp is in the low 40s. And the tractor is stored outside with just a high roof to keep the rain and snow off.
Eric
/ Fuel additives #11
I use the Power Service white container year round so I
am always ready for any temp change so I don't have to
have some diesel for summer and some for winter its all
the same year round
willy
/ Fuel additives #12
if the local station is reputable and keeps their tank fuel current,
and the distributor/wholesaler and their guys are on the ball with their additive packages and reputable and keeps their fuel current,
and you keep the fuel in your tractor current and free of moisture (like not pulling a cold tractor into a warm shed to the point of condensation forming) and not using biodiesel which seems to attract moisture,
and you are operating in a climate that is not really / really cold,
then no you have no need or worry about using an additive.
Me... I don't like to take the risk, I use reputable supplier, keep my fuel current to the season, store in unheated shed, and avoid biodiesel at all cost but for peace of mind / insurance I use PS anti gel. Cheap, easy to add and provides good peace of mind. Every year operate at sub 30 degree levels (moving snow and in my woodlot) and never had a problem. On rare occasion -40 but only when absolutely have to. This week i put in a full day just a little colder than -30 with my no cab L3301 Kubota w/ F/X85 logging winch in my woodlot.
I always wonder about these ".. should I use" discussions.... I tend to think more "why not use"??? cheap and easy insurance IMHO
/ Fuel additives #13
I got caught with diesel gelling last week. Temperature was minus 6, no idea of how much colder it was considering wind chill. Couldn't pump diesel out of my bulk tank because it was gelled in the fuel filter bowl.
So it's up to you. If you don't get temperatures all that low you may be OK with whatever the refinery or reseller put in it. But if you get a sudden cold snap you will be in deep trouble when the diesel gells. Your tractor WILL NOT run until you clean out the wax formed by the gelling diesel.
/ Fuel additives #14
From what I have seen, read, and heard over the years this is a debate subject every year.
It seems to me that their are two main classes of individuals and two main trains of thought.
Those that have gelled and fought to get going in miserable weather and those that have not.
With two different theory's on what to do.
Those that have fought gelling and had to get going regardless of what it took, laying in snow to remove filters, blowing lines out, using heat (often fire) with sometimes disastrous results, most times eventually succeeding.
And those to which it has not happened yet.
I guess their should be a third group those whom have had minor cases of fuel gelling and have walked away and had someone else come take care of the problem, so it was a minor aggravation to them.
Those that have fought the issue, especially more then once do not have any desire to do so again.
Those that have not, seem to consider it to be a none issue.
/ Fuel additives #15
Treating fuel with an anti-gel will never hurt anything and like someone else said, it is insurance. I would rather spend the money and treat the fuel then out to find it the tractor won't run because the lines and tank are full of jello. I have never had a problem with gelling and I never want to have a problem with gelling.
So to Lou's list you can add the camp of: Never dealt with gelling and don't want to find out. We are probably a small group.
/ Fuel additives #16
I'm in this group. I've never used an antigell either. I keep a small supply of diesel and gas in jerry cans for my tractor and mower but they are always emptied and refilled to coincide with the seasons.
I was told by my fuel supplier that their fuels (which are refined in Regina SK) always had the current required seasonal additives. So far I haven't had any diesel issues. I did have problems with my gas Audi once in -30C weather but that was resolved by letting it sit on the road for about 1.5 hours and then driving it back home and adding gas line antifreeze.
Just for the record we only have 3 gas engines. My quad, a 1947 IHC KB-1 and the Audi. All the rest are diesel. 2 Jetta's, 2 Cummins, lawn mower and a CUT. There's more but these are the regularly driven vehicles. Well except for the quad and the 47.
I don't ever want to deal with gelled fuel but if it happened I would most likely just push the vehicle into my garage and turn up the heat. After reading through this thread I concider myself very fortunate.
/ Fuel additives
Most of you have given sage advise that was requested, thank you.
Fuels change over the years, and I'm not up on those changes. Maybe diesel doesn't change, that was the reason for my question, is it necessary to add additives. It wasn't a matter of feeling lucky, trying to save money. I stated I used an additive last year. Just trying to figure out if "modern" fuel still needs it. Thanks again to those who read and answered...
/ Fuel additives #18
Yes, if you buy your fuel in the season you use it then there is little chance your going to have a major problem.
But I keep plenty of fuel on hand and I don't keep track of when I filled each of my 5 gallon cans. I rotate the cans and use the oldest. I don't want to make a trips get fuel as I need it, at times this would be once a month but in the winter it could mean several trips a week. I don't want to take a chance of needing to move snow and be out of fuel because it's been a bad snow week and I've used it all, been there, done that. For this reason I treat every can, it's just easier that way.
/ Fuel additives #19
I live 10 miles from a card lock that I'm in the vicinity of several times a week. I can get fuel any time of day and any day I want. Chances are good that if I was in your situation I would do the same as you. I'm fortunate in the fact that I don't need to.
/ Fuel additives #20
seems to me there are 4 possible issues w/diesel fuel.
gelling, lubricity, algae growth, moisture in the fuel.
don't think i've ever seen a conditioner that addresses all 4. personally, i took the advice of my K parts guy & go w/Howes, as it covers 3 of the 4 above (but not algae). he mentions it's a favorite of truckers, tho i can't confirm that. good luck, & yes, i agree preventative is always better than after the fact
(96) 1"X8"X10" PONDEROSA PINE BOARDS (A62131)
(96) 1"X8"X10"...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Bucket Truck (A60352)
2018 Freightliner...
2017 Autocar Xpeditor T/A Heil V-161 Front Loader Garbage Truck (A61568)
2017 Autocar...
1994 SHOP MADE ENCLOSED TOOL TRAILER (A58216)
1994 SHOP MADE...
UNUSED RAYTREE RMSC78 - 78" HYD SOIL CONDITIONER (A62131)
UNUSED RAYTREE...
02GER CHICKET HOUSER 240F (A62131)
02GER CHICKET...
