New MF GC1723E owner. What next?
/ New MF GC1723E owner. What next? #21
Diesel fuel treatment for the northern climate is a must.
Everyone will have favorite brand. I like Hot Shot's Secret Diesel Winter Anti-Gel.
/ New MF GC1723E owner. What next? #22
Is that your tractor in your avatar? If so, I assume you got the loader as well. If not, then that would be the first implement I would recommend you get. They are invaluable.
Dave
/ New MF GC1723E owner. What next? #23
Thanks for all the input folks. Like the lists a couple of you supplied. I'll be well prepared. Definitely see the recurring theme here on the shear pins. Going to find a good local supplier for those ASAP and always carry.
When I said I was a newbie, I mean even my first diesel anything I've owned. So one other question in my mind is will I need some kind of anti-gel fuel additive here in Northern MI? I see that talked about on here once in awhile. Is there a particular brand?
Wassup, welcome to the forum and to the GC set! *throws up MF gang sign* I get confused by the new GC model names, is yours with the backhoe?
Regarding fuel additives, here's what I do. I use Power Service year round, the white bottle in the winter, the grey bottle the rest of the year.
In either case, I toss 2oz of it into a 5 gallon fuel can. I also use a Biobor JF biocide, around 5cc of that into the fuel can.
I pour all that into the fuel can prior to filling it up, which in my mind helps mix it all up.
In the winters, when I'm filling up the tractor from a partially full fuel can, I use a Mr. Funnel which separates any water condensation that maybe formed in there. This thing: Amazon.com
Definitely have some spare fuel filters on hand just in case the fuel gels up, but I will also say that with me doing all that up there, that has never happened to me yet.
Here's where I get my filters: Massey Ferguson GC1700 Filter Service Pack.
If you're gonna change the hydro oil too, make sure to also add the filter listed near the bottom of the page.
As far as the o-rings listed there, I've done a full service a few times now, and I've yet to change any o-rings. But I suppose good to get them one time, so you have some on hand just in case.
As far as oils, I use Rotella T6 engine oil. For hydraulic oil, I use Amsoil (order direct from them).
I've got some Youtube vids related to my GC which you may find useful, you could check me out. Here's one for the Mr. Funnel:
/ New MF GC1723E owner. What next? #24
Oh yeh, regarding must haves for the Massey, really depends on what you're looking to do with it and also if you got a backhoe.
If you're gonna be going into places where a stick could wreck your hydro fan, you definitely want a skid plate down there as already been mentioned by Hube (I think). You could buy one, or make one. I made one, it's pretty easy to fab up a basic one.
A Ratchet Rake is a great tool for around 300 bux. It straps on your loader bucket and you could do all sorts of stuff with it.
Pallet forks are real nice to have, but also with the caveat that most of the ones out there have a much higher load rating than a SCUT could ever hope to lift...at the expense of being heavy themselves, which lowers your lift capacity yet more. I did quite a bit of research on that, and finally got these which I'm very happy with (both product and pricing): Standard Duty Pallet Fork Frame with 42″ 2,200 Pound Pallet Forks Fits Skid Steer Quick Attach – Black – Skid Steer Attachment Depot
If you have a backhoe, adding a thumb to it is a real nice addition. But I will also say that I modified mine (Bxpanded), and it's now way way more useful.
You got a bunch of grease zerks to hit on the Massey, and you'll get advice here to get a powered grease gun for that. My advice though is, unless you got some hand issues, save your money. I use an Alemite 555-E manual grease gun with a LockNLube coupler, was $90 total on Amazon. Works great and super easy to use.
That Rachet Rake looks like it would be useful on my wooded 15 acres, something to consider in spring.
A couple of you mentioned "skid plate" now is that this "Sentinel" link here...
And is there such thing as a new tractor smell? I got to really use it this morning, got 5" or so of snow so put it to work. Smell is not super strong but I get a whiff every now and then like a combination of maybe clean oil burning off of metal, like maybe new parts that had a coating, with a combination of like rubber or plastic that has been warmed up for the first time. I'm guessing this is my new tractor smell, it only has 2 hours on it now.
And I have to say using it this morning to blow snow was actually fun. It worked perfectly. I just hope that now wife doesn't find out I enjoyed it or that will change the dynamic of who does what chores.
/ New MF GC1723E owner. What next? #26
Yeh, that Ratchet Rake is one of my favorite tools for sure. You might wanna get some hooks on the loader bucket too, thems real handy.
/ New MF GC1723E owner. What next? #27
Yes, Sentinel is the one I was talking about
/ New MF GC1723E owner. What next? #28
Yes ditto. I got the bolted on hooks which work great lifting anything with chains. I also have the ratchet rake which I use for cleaning out ditches from rocks and leaves.
/ New MF GC1723E owner. What next? #29
Get a battery powered grease gun. I cheaper out for a while and after I bought one I felt stupid for not doing it right off the bat.
/ New MF GC1723E owner. What next? #30
...And OOPS!
Blew the fan shear bolt today... didn't see that 1" diameter piece of branch that blew down today. A 12" long piece, it was buried in the 3" of wet snow we got.
Realized I was wrong above -- they take a 1/2" wrench & socket, not 7/16".
For those who may be interested, here's the Kubota part number for the impeller shear bolt -- a fair bit less expensive than the M-F part, but identical.
Interesting that the Kubota part says MADE IN USA, but the M-F/AGCO part says MADE IN CANADA.
2021 UTILITY VS2DX 53FT DRY VAN TRAILER (A59905)
2021 UTILITY VS2DX...
20' DOUBLE AXLE INDUSTRIAL TRAILER (A59823)
20' DOUBLE AXLE...
KJ K1912 20'x12' Shed (A60463)
KJ K1912 20'x12'...
2020 Deere 750K LGP (A53317)
2020 Deere 750K...
2019 Chevrolet Tahoe SUV (A60352)
2019 Chevrolet...
2013 CAT 950K WHEEL LOADER (A60736)
2013 CAT 950K...
