GC1723 50 hour Maintenance Questions
   / GC1723 50 hour Maintenance Questions #51
All the advice so far has been spot-on.
Do not run the engine with the hood up. You will burn the paint off the hood.
Have a can of brake parts cleaner to clean the hydraulic intake mesh.
Check under where mud can get up in and block up your hydro cooling.
If you have a BH, it's the perfect time to take it off and exercise your 3pt hitch parts. I use white grease on those parts.
   / GC1723 50 hour Maintenance Questions #52
One thing my former shop supervisor always said, "Oil is cheap." As a matter of fact, so are filters and so is grease. I just change things and do maintenance according to the owner's manual. There are no guarantees that things won't break, but when and if they do, I won't be thinking "I wish I would've..."
   / GC1723 50 hour Maintenance Questions #53
this.
in fact to actually service a GC series hydro system the backhoe must be off and 3pt lowered.
I am not a backhoe tractor so my 3pt in use almost daily. on the items w/o grease zircs I use WD40 white Lithium spray. and I also clean and lube my top link quite often as there is a difference of top link adjust between my tiller, my trailer hitch, my snowblower, and my 7ft grader blade. really sucks when top link is frozen up....
   / GC1723 50 hour Maintenance Questions #54
It's 2024.
Cheap oil, is kind of cheap.
Good oil, is NOT cheap. 5 gallons of good hydraulic oil, is now $200. The hydraulic filters on these are $50, and there are still no cheap engine oil filters, that are officially listed for these. So, it's well over $300 to do oil and filters on a subcompact now.
Taking out good clean oil, to put in cheap oil, (done far too often), could also leave you wishing.
I know, "It's cheap compared to the cost of the machine", That point is moot, because it's not cheap.
CATERPILLAR 48" QUICK ATTACH FORKS (A51242)
CATERPILLAR 48"...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2017 Ford E450 Super Duty 20 Passenger Bus (A47384)
2017 Ford E450...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2021 CATERPILLAR 953 CRAWLER LOADER (A51242)
2021 CATERPILLAR...
2013 LONE STAR TRAILER MFG. (A50854)
2013 LONE STAR...
