GC1723 50 hour Maintenance Questions
   / GC1723 50 hour Maintenance Questions #51
All the advice so far has been spot-on.
Do not run the engine with the hood up. You will burn the paint off the hood.
Have a can of brake parts cleaner to clean the hydraulic intake mesh.
Check under where mud can get up in and block up your hydro cooling.
If you have a BH, it's the perfect time to take it off and exercise your 3pt hitch parts. I use white grease on those parts.
   / GC1723 50 hour Maintenance Questions #52
One thing my former shop supervisor always said, "Oil is cheap." As a matter of fact, so are filters and so is grease. I just change things and do maintenance according to the owner's manual. There are no guarantees that things won't break, but when and if they do, I won't be thinking "I wish I would've..."
   / GC1723 50 hour Maintenance Questions #53
this.
in fact to actually service a GC series hydro system the backhoe must be off and 3pt lowered.
I am not a backhoe tractor so my 3pt in use almost daily. on the items w/o grease zircs I use WD40 white Lithium spray. and I also clean and lube my top link quite often as there is a difference of top link adjust between my tiller, my trailer hitch, my snowblower, and my 7ft grader blade. really sucks when top link is frozen up....
   / GC1723 50 hour Maintenance Questions #54
It's 2024.
Cheap oil, is kind of cheap.
Good oil, is NOT cheap. 5 gallons of good hydraulic oil, is now $200. The hydraulic filters on these are $50, and there are still no cheap engine oil filters, that are officially listed for these. So, it's well over $300 to do oil and filters on a subcompact now.
Taking out good clean oil, to put in cheap oil, (done far too often), could also leave you wishing.
I know, "It's cheap compared to the cost of the machine", That point is moot, because it's not cheap.
1043 (A50459)
1043 (A50459)
2013 Ford F-150 (A50397)
2013 Ford F-150...
2008 Isuzu NPR-HD Landscape Dump Truck (A50323)
2008 Isuzu NPR-HD...
ATLAS 10 1/2' DISC HARROW (A51243)
ATLAS 10 1/2' DISC...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
2007 INTERNATIONAL 4200 SBA 4X2 DUMP TRUCK (A51243)
2007 INTERNATIONAL...
