/ Harbor Freight Tools that don't suck #15,601
I did pick up 2 late today.
the customer rating on those are amazing, 600 folks unanimously giving it two thumbs up.
looks like a good tool at a fair price.
Now if it's a great tool at a fair price, which this seems to be,
we seem to have a winner.
/ Harbor Freight Tools that don't suck #15,602
Far as I'm concerned today, the only junk HF stuff is the 'Warrior' line. The rest is pretty good. Even the Pittsburg stuff is acceptable but the Chief and Icon and the tool cabs are all excellent as are the Vulcan and Titanium welders and plasma cutters.
I have a Vulcan Pro-Tig 205 and it is much better and tons cheaper than my Lincoln Square Wave TIG which I've sold and I bought 2 Titanium plasma cutters a 65 amp for use on my CNC plasma table and a 45 amp for general hand use. and both were less than the Hyper-Therm I had that I sold as well. All the Vulcan and Titanium welder come with a one year guarantee which I extended to 3 years.
The Pro-Tig is especially user friendly with it's built in presets and full digital control. I did upgrade the standard TIG torch to a CK 250 amp water cooled unit and a water cooler however. The gas cooled torch isn't good for aluminum welding at maximum amperage. It's only a 150 amp torch.
When I purchased the Pro-Tig and the Vulcans I also purchased the Large Vulcan roll around welder cart. It's also a high quality piece. Ball bearing soft lock drawers, room for 2 full size bottles (I run 120's) on everything that requires gas shielding except my OA torches. They get a 180 OX bottle and a A sized acetylene bottle, or maybe it's not an A, it's a big one too... I keep my Hobart 210's separate carts.
/ Harbor Freight Tools that don't suck #15,603
Hf experts that own/ use a hf air chisel how are they? My elcheapo one quit working in the market for a new one and considering hf.
/ Harbor Freight Tools that don't suck #15,605
Have one of those as well. Mine works fine but I do use air tool oil in it regularly. It's the HF cheapie.
As do I in everything pneumatic, if it was nicer I'd probably attempt to take it apart, might do it anyways just to take it apart lol.
/ Harbor Freight Tools that don't suck #15,606
HF has everything on sale for 4 days now at 25% off. Might get me2!
If you look at the fine print on those 25% coupons over half the stuff in the store is exempt from that discount.
/ Harbor Freight Tools that don't suck #15,607
/ Harbor Freight Tools that don't suck #15,608
My air is very dry so no moisture gets in my tools except maybe a little in the air line and piping but all my piping is in black iron with a downward slope and I drain that off of every down leg anyway. I have a refrigerated dryer on the main feed from the main compressor and my secondary screw compressor has a built in air dryer. To be sure I get it all, I have a Tsunami auto drain on the main compressor that dumps and water in it every time it cycles. Water kills air tools.
/ Harbor Freight Tools that don't suck #15,609
That's a lot nicer set up than mine. This is the first pneumatic tool that's ever completely failed on me besides nail guns. But your probably correct water killed it, line out of compressor is finned going into tank, a ball valve in easy reach on bottom of tank to drain water occasionally, one pretty decent self draining filter before it enters my semi ridgid max air brand lines and another smaller regulator filter in my shop I use for occasionally painting. I do completely drain and shut air compressor down occasionally. It's only a 60 gallon single stage but has been pretty good and handy for my usage.
/ Harbor Freight Tools that don't suck #15,610
The secret is to not shop there for a few months. HF will then email you a letter saying "we missed you" with a coupon for 25% off any one item in the store with no exceptions (other than gift certificates and club memberships).
When you buy your big ticket item, make sure to buy another doo-dad or two, and stop by a week or so later and grab something else. I'm told they track whether that special coupon gets you back and buying other things. If so, you are more likely to get another one in the future if you are absent for an extended period. If I don't need another tool, I'll just pick up some consumable, like zip ties or a pack of angle grinder cut-off wheels.
2023 John Deere XUV 825M S4 (A60462)
2023 John Deere...
2021 CATERPILLAR CB1.8 DOUBLE DRUM ROLLER (A62129)
2021 CATERPILLAR...
Wacker Neuson PT2 Water Pump (A59228)
Wacker Neuson PT2...
2000 REITNOUER ALUMINUM FLATBED TRAILER (A60736)
2000 REITNOUER...
2018 Multiquip AR-14 (A60462)
2018 Multiquip...
2020 CAT 308 (A53317)
